LG GT2, C6Z06 sway bars, C6 end links - good combo?
Old 10-18-2016, 10:08 AM
raztek
raztek's Avatar
Default LG GT2, C6Z06 sway bars, C6 end links - good combo?
I have LG GT2 coilovers that I am about to install and was wondering if going with C6Z06 sway bars would be a good combo. I have 275 fronts and 305 rears Nitto Invos on 18/19" rims. Are there other options for end links that would make sense over replacing my end links with the C6 ones.
I don't currently track the car but am pretty spirited when carving curves. May decide to track it a few times a year at some point.
I am currently slammed (front bushings removed) with longer rear bolts out back on Bilstein shocks. Everything else suspension wise is stock Z51.
Car is a 2000 C5 coupe 65,000 miles (end links are shot for sure).
Would appreciate your thoughts. Thanks.
Old 10-18-2016, 11:53 AM
charger21
charger21's Avatar
C5 of Year Finalist (track prepared) 2019
For what you are using the car for, that combo is gonna be fine.
Old 10-21-2016, 08:59 AM
raztek
raztek's Avatar
Thanks charger21 .
Anyone else that would be able to provide any insight?
I have done some searching and have read that i should reinforce the shock mounts. Is that necessary?
Have also read that with the bigger rear c6 z06 sway bar, that the tail will have a tendency to break loose. Is this true even with moving to a coilover set up? I have 2000 Z51 sways right now.
Thanks - hope others that have made similar mods are willing to share their experience!
Cheers
To LG GT2, C6Z06 sway bars, C6 end links - good combo?
Quick Reply: LG GT2, C6Z06 sway bars, C6 end links - good combo?
