*PICS* - Installed 2017 OEM Track Brakes Ducts and Wheel Blockers
*PICS* - Installed 2017 C7Z OEM Track Brake Ducts and Wheel Blockers
Installed the OEM Track Brake Ducts that came as standard equipment on my 2017 1LZ Z06 with iron rotors.
Kit consists of four pieces.
- Two "clamshell" pieces which mount around/encapsulate a portion of the leading strut of the lower control arm.
- A riser which attaches to the clamshell pieces directing air upward/vertical befor turning 90 degress towards the rotor. The outlet ends several inches inside of the rotor/spindle. If they extended any further I believe they'd hit the spindle while turning.
- A riser support bracket which attaches to the top of the riser and also serves as a deflector at the bottom directing air into the duct intake. This piece also adds strength as it attaches to the leading strut of the LCA.
Note I didn't install the wheel blockers as I ran out of time. I think I'll mount them and leave them on all the time even though GM says to only use them on track. I can't see how they'd do any harm.
The wheel blockers capture air coming from the riser outlet and directs it down and around the rotor and through the rotor vanes.
Also, you do not reuse the existing air deflectors mounted at the factory that you remove as the first step of the installation of the track ducts.
The kit is also 100% independent of the existing brake ducts off the grill which just dump air into the wheel well.
Only tool needed to install is a small torx socket or driver. Install of the first side took a little over an hour. The other side took 15 minutes. The instructions are sort of difficult to follow.... Not hard just have to figure it out.
It took more time putting this damn post together than it did to install the ducts....
FWIW, I've put 970 miles on the car in less than a week. Need to get to 1,500 to get on the track. I'll have that by the end of this weekend.
I do not have part numbers for the kit. I previously posted part numbers but was informed they are the numbers for the install instructions. BTW, the install instructions are in the owners manual.
Rick
DISCLAIMER: I'm not giving up my day job to become a photographer....
The track brake duct the clamshell intake pieces put together and the riser installed onto the clamshell pieces:
Angle shot of the top of the track duct riser outlet directing air to the rotor and uninstalled wheel blocker:
Top view looking down onto the outlet of the track brake duct riser directing air to the rotor and the uninstalled wheel blocker:
Track duct air intake mounted to the lower strut of the LCS:
Ground level picture of the track duct air intake. Look inside and you can see the encapsulated leading strut of the LCA:
Unistalled wheel blockers. You take the caliper and rotor shields off to install these in place of the factory installed rotor shields. They install on the back side of the rotor:
Rick
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
I would think these should work equally well on a J57/CCM brake car. The blocker ring maybe not, but the duct would still direct air to the appropriate place. Now the front carbon rotors may not be designed to effectively take that air and send it through the vanes, but that is another story.
Wonder how long it would take to get my hands on a set of ducts from GM. I'm guessing it will be next year before they are available due to constraints/backorders, etc.
Received 2,673 Likes
2018 C5 of Year Finalist
So this kit comes with all 2017 Z06 models with the steel brakes?
I already asked Subchev to look into it. Will be my winter upgrade along with the Aux radiator.
He noted that the part numbers above were for the instructions, not the actual parts.
Received 8,918 Likes
Bill
As stated in my post and pictured these surely do grab air from under the car. The 4th picture in my post was taken with the car on the ground and the camera right behind the splitter. Basically, a head on shot of the intake at ride height. Debris will get in them but it might be difficult to get through the two 90 degree bends that exist before the rotor. No different than debris getting in the ducts catching air through the grill or like the ducts we used to run on the C6Z with the Quantum or LG ducts.
They will pick up/catch debris and restrict air flow or damage/hit the rotor. As such, I've already thought about putting a wide mesh screen on the air intake. Something that wouldn't restrict air flow too much.
Rick
BTW - the 2017 is now up on the Chevrolet Build It Site and they don't list these under accessories, so they are probably included on all 2017s.
Thanks. I've seen two separate threads on this nice "delivery surprise" but on the Chevrolet build it site for the 2016 Z06 they were listed under accessories.
I was thinking they would come with all dry sump engine equipped cars, however, a friend of mine took delivery several weeks ago of a 2017 Grand Sport and he didn't get them.
Found out some more info. The ducts are listed as an option for the GS, standard on the Z06/GS J56 cars and are restricted to cars MY 2016 and newer. That may mean there were more mounting holes or different holes drilled into the LCAs. Might be interesting to see if there is a difference in part numbers for the 2015 and prior LCAs and 2016 and later LCAs. There isn't anything about the ducts being made available as a separate kit or as an accessory. However, that could change after SEMA. There are no part numbers released yet.
Bill
Bill
Note the ducts offered as an option on the 2016 C7Z are NOTHING like the ones that I received with my 2017. The ones that came with my car are much more complex/effective than the ones you refer to. In my prior thread someone posted a picture of the ones you reference. Big difference and those did not come with wheel blockers.
A link to the original thread I wrote is below. Scroll down to Post #4 and you'll see the ones you reference as being available for 2016. Apples and oranges....
https://www.corvetteforum.com/forums...-blockers.html
I would be surprised if they came with "all" 2017 Corvettes. I imagine you were inferring all 2017 C7Zs?
