I'm in love
I'm in love
Just drove my 2001 m6 coupe home from Scotty's (my mechanic) with a new 4.1 differential. The daily driver has 214,000 miles on it (all mine) and I wanted a little more "get up and go" that didn't require maintenance. The only performance upgrades I've bolted on is vararam intake. Last year I purchased a COW tune. All were worthwhile, but the love is back with the 4.1.
What does the car turn at 70? Just curious?
Shakey
Shakey
[QUOTE=Shakeydeal;1593294941]What does the car turn at 70? Just curious?
1800 rpm which actually makes 6th gear almost usable!!!
Road Runner (10-20-2016)
St. Jude Donor '13, '15
How bad of an install is a rear gear change? I've got a 2004 base automatic with I believe 2.73's. Diffs seem to be relatively inexpensive used, labor probably costs a bundle though?
99blue frc (11-14-2016)
I installed a 4.11 in my 1972 454CID 550 HP and it was awesome, but I also installed a Hone Overdrive that would switch it over to 2.87 on the fly. Best of both worlds...
[QUOTE=Road Runner;1593295620]I had a 2000 WS6 M6 with a Moser 12 bolt and 4.10's H/C/I and it turned 1900 rpm at 70 mph. I still got 22-23 MPG on the highway which is good for a car several hundred pounds heavier.
Received 19,293 Likes
'20-'21-'22-'23-'24
That gearing has to set you back in the seat when you floor it.
1/4 mile/AutoX
you have the luxury of so many units out there, 3.90 and 4.10 not so much. if you did just the dif change, I don't think it's a very big deal !!!
1/4 mile/AutoX
4.10's is the mod I want to do badly !!!! I need to know what rpm at 80 mph, I never go 70 mph
Nice I am considering 3.73 or 3.90 gears. Do you find you are shifting a lot more with the 4.10's also?
1/4 mile/AutoX
I had 4.10 gears on my '80 C3 with the anemic 190 hp 350ci...let me tell you I do recall having one heck of a blast on the streets. Smok'n most everything on the streets. Fun sharing my Corvette's spec's...forgot the mention the gearing...lol.
1/4 mile/AutoX
back when I was young with a 375 hp 396 Camaro I went from 4.10's to 4.88's
