Dressing up the engine bay
What are some easy, and inexpensive things you can add to dress up the engine bay? I plan on adding a hood liner with the Corvette flags, and if the car I buy doesn't already come with them, I'd like to add the red valve cover covers (what are they called)? Where's a good place to buy these parts?
Received 19,303 Likes
'20-'21-'22-'23-'24
And depending on what color you end up with, someone might be selling some used dress up pieces that would compliment the color.
FRC, 'fuel rail cover'.
frank
frank
The hard part is "cheap".
I was lucky enough to buy a C5 at a great price, and some previous owner had spent maybe $ 1000+ under the hood. All this simply sticks on w/ velcro, but I think it looks good:
First, spend a couple of hours hitting every nook and cranny. A clean engine bay looks better than one dressed up with little trinkets w/o the attention to detail.
Also, don't forget that sometimes less = more. Don't go overboard and make it gaudy. There is one yellow corvette on this forum that went waaay too far in that direction. The owner shall remain nameless.....
Shakey
The following 3 users liked this post by Shakeydeal:
2018 C5 of Year Finalist
St. Jude Donor '14,'18
Easiest way to always have a clean engine bay. Everything is covered and makes a great crowd pleaser.
The coil covers are wet decal dipped with carbon design and light grey base coat.
Pounder (10-21-2016)
Received 1,679 Likes
Banned Scam/Spammer
Received 1,319 Likes
If you don't mind a project you can polish aluminum...
I've got about $100 in polishing supplies and a lot of time spent.
The power steering pulley bracket was $100 and the aluminum intake was bought for around $300 unpolished if I remember correctly. The rest is time.
Block timing cover and valley cover ready
Alt bracket
Alternator
Water pump
Mock up with the water pump/tb installed
PS pump and bracket installed on the engine, also steering rack/ebcm.
Assembled
Coolant Crossover bolted down with more polished button heads
Alt bracket
Alternator
Water pump
Assembled
Awesome work Josh!
~Josh (11-21-2016)
St. Jude Donor '13, '15
I think I know who you are referring too... Unfortunately I think there are many more on this forum with the same. To each their own. I started going down that path, but now I'm course correcting and going with the naked approach.
1/4 mile/AutoX
1/4 mile/AutoX
1/4 mile/AutoX
The OP did say inexpensive ???? I bought all my Stainless as a kit from e-bay for 300 dollars, all the painted stuff I did myself with base/coat clear coat spray cans from Automotive touch-up.com !!
