Service active handling system error - help!!!
Guys, need help!!!
got my car detailed last week and the knuckle head wet my bcm under the passenger side foot rest, now I took it to anoder place n got the bcm flashed, reprogrammed n fixed after it was showin a lotta fault codes.
todsy, was driving around n suddenly the service active handling system error code appeared, n my cruise control doesn't work either, this happened when the car was at about 70 km/Hr and when I braked suddenly,
now, I usually had to just place my leg on the pedal to get the car started but for the past 2 days since I got the car back, I hav to press it in really hard to get it started, I had also bled the brake fluids at the workshop this time
any suggestions as to wat cud b the problem guys?
Cud it b a fault in d bcm? Or is it a faulty brake pedal sensor module?
how do I check?
kindly advise
how do I check?
kindly advise
Law Dawg Moderator
