side pipes
side pipes
I have a 1963 with sidepipes They need to be replaced I see that there are 2" and 2 1/2" is there a way to tell what size they are without taking them off thanks vince
I would assume they are speaking of the diameter of the head pipes leading to the chambered pipe sections. If so you can reach under the car and caliper the head pipe diameter. As far as the chambered part - your pipes could be anything - OEM or aftermarket. OEM was 1-5/8 inch clear through the chambered part. Most aftermarket pipes now are 2-1/4, 2-1/2 or 3 inch through the chambered section.
Divide the circumference by 3.14 to get the diameter(s). For 2 inch pipe the circumference should be about 6-1/4 inches. For 2-1/2 inch pipe the circumference should be about 7-7/8 inches.
There are three choices for "factory type" pipes:
1. 2 inch diameter all the way from the exhaust manifold to the side pipes. This size was never offered from the factory, but could be a custom set made/altered specifically for your car.....if it was initially an auto trans car. Probably unlikely.
2. 2-1/2 inch diameter all the way. Used on most of the early C2 cars with 4-speed. Probably what you have.
3. 2 inch diameter at the exhaust manifold and then swaging up to 2-1/2 inch about 6-12 inches later. These were factory installed for the 1966-67 small block cars. You could have these if your engine exhaust manifolds were replaced with 66-67 type.
In summary, measure for the actual pipe diameter or diameters (2) and determine whether swaged or not.
Larry
EDIT: In recent years, the side pipe shops have been offering just about anything you want..........so just about anything is possible. But the choices I mentioned above should cover most "factory like" systems.
Basically, the 2" and 2-1/2" are the opening at the exhaust manifold. This was because most Ramhorn manifolds were 2 inch but the high performance ramhorn manifolds expanded near the flange and were 2-1/2 inches.
Notice how the lower one is slightly larger near the outlet. You can measure the pipe near the flange to see.
If you have stock manifolds on, a 250 hp and 300 hp will be 2 inch. A 340 and 360 hp will be 2-1/2 inch.
If you have headers, then you are going to have to do more measuring.
