Crossmember Dents
Crossmember Dents
So my 63 roadster`s crossmember is dented in (lazy floor jack placement) and I have seen the corvette crossmember dent removal tool. Has anyone used it ? Does it actually work ? Is it a pain to use ?
Larry
Never heard of it - anyone got a pic or instructions on how to use it..?
Yeah Frankie, it's a tool that slips inside the front crossmember and jacks the dent out that's caused by people jacking the car up there.
http://www.zip-corvette.com/63-82-fr...pair-tool.html
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
St. Jude Donor '11-'24
Crossmember Dent Removal Tool
Tfringo is selling a few of these tools. I got mine yesterday. Send him a pm to see if he has any left.
Bob K.
Bob K.
I cannot remember all of the details or the person who first built it, since it really didn't pertain to me or my car. But perhaps others can provide the details or earlier threads.
Larry
EDIT: Here is one of the early threads. https://www.corvetteforum.com/forums...ty-pics-3.html Checkout all 3 pages of the thread. As stated above, Tfringo was the tool builder/originator. I believe his name is Terry Fiala.
Here is a second thread on the topic. https://www.corvetteforum.com/forums...-corvette.html
2) yes I have used it
3) yes it's a PIA to use
You need a big *** breaker bar to have success
When facing that problem, I decided to reinforce the center cross member (what should have been done originally) so I cut out the dented area, fixed it on the bench, reinforced it with 1/4 inch steel and welded it back in. All the cuts were under the license brackets and it was an invisible upgrade. now I can jack it up in the center with no ill effects. It's a great upgrade if you have the skill set or know someone who is a good steel fabricator. Pilot Dan
I'm with Dan, if I had this to do again I would cut, fix and weld.
My friend is restoring a 1963 Z06 and posted this on Facebook...
Here's an easy way to remove dents from the typical jacking spot, under the front crossmember. Install this tool, draw the bolt down to work the dents out. It will require you to install and remove the tool a few times, adding shims to the "shoe", to work the dent out almost completely. In between steps of pulling, I sand the surface with a block and some 36 grit paper. Blocking it out tells me where the low spots are, and I can track my progress.
In the end, I was left with a few 1/16" deep low spots. I can work them out the rest of the way, from the few holes in the top of the frame. The only other way to work out the remaining low spots, would be to cut the piece out, hammer and dolly the damage out 100%, then weld it back in place. In this case, the damage wasn't severe enough to warrant any cutting. The rest of the low spots will be worked out 100%, only requiring polyester primer to blend and smooth everything out.
Received 3,443 Likes
Pretty cool. Never heard of such a tool. Good stuff!
interesting
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Is it hard to use... Nope.. you just need to take one side of the front suspension apart and insert the tool into the front crossmember. Once iniside the crossmember you just position it in place and let the tool do the work for you.
There are only two ways to repair the dents.. one is to replace the lower crossmember skin and the other is this tool. The cost to remove the lower skin is way more expensive than to just purchase the tool.
https://willcoxcorvette.com/front-cr...963-1982-26653
Use the current sale code and save 10 percent off.. The sale code is listed on the front page of our website.
Wiillcox
Wiillcox
Nice job! Terry
ttt
Wiillcox
Wiillcox
