[Z06] wot = damaged piston
I saw a intake valve do that to a spark plug. The guide was so wore out, the intake valve was wobbling around so bad, it smacked the spark plug gap closed.
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,095 Likes
More than likely wot & detonation= damaged piston. Could even be a cracked liner too. I see you're supercharged too. 10 to 1 that engine will have to come apart. The block may be toast too. Sorry for your bad luck.
Time to trade it on a c7z or take it to car max and sell it.
Supporting Vendor
Received 1,012 Likes
We currently have our package 4 reworked LS7 Core heads on the shelf and ready to ship out so if all you need is a set of heads give us a call
310-326-2399
Once you pull the heads you will know the extend of the damage. Hopefully you just need a new set of heads and your back up and running.
http://www.americanheritageperformance.com/
310-326-2399
Supporting Vendor
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes
St. Jude Donor '08
I'm gonna throw $50 towards detonation causing a ring land to break and more damage will be found when the head comes off.
The old #7 cylinder strikes again. Agree with others...detonation is no joke on these cars, especially if the OP is FI. My money is on piston and sleeve damage as well. Sorry for your loss, but yeah...start the teardown process.
RichieRichZ06 (10-27-2016)
My bottom end came from Late Model Racing. They have great options for you on every level. I feel their prices are fair as well. Give them a call. Heads use AHP or WCCH. They both do fantastic work. Someone else may suggest a local builder but I am unfamiliar with your location.
jackhammond21 (10-25-2016)
