Wheel Tire Package Direcdt Bolt On?
Hello All,
Will this set up be a direct bolt on with no spacers?
Has any of you ever had dealings with this company? Its a 94 Coup
Thanks in advance,
MM
http://www.ebay.com/itm/332010350745?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Thanks in advance,
MM
219fit (10-24-2016)
I don't have any first hand experience with those wheels, but the hub bore, bolt pattern and offset seem to be correct. Also in the information it states that they will fit '88-04' Corvette's so I would say they should fit
If you have any doubts though you can also contact the seller and ask about fitment, just to be sure.
219fit (10-24-2016)
Pro Mechanic
Received 3,952 Likes
you could also contact forum vendors for pricing as well.....................
Bob at House of Wheels, although they may not have tires, or
Doc@1st Rate Corvette, who does handle wheel and tire packages.....................
I do want a wheel tire package. My car is low mileage with the original wheels and tires. I'm just going to pull them and set them aside. Thanks for the info.
Pro Mechanic
they have a website as: www.floridaspeedshop.com so you can check them out
219fit (10-24-2016)
Doc@1st Rate Corvette would be your best option then...........
CCW wheels have been very popular but the company was recently sold so I can't say things will remain the same. Vintage wheel care.
Richard Newton
Richard Newton
Supporting Vendor - Supporting Member
You had to click on the picture to get to the listings. The second link below is for the C5 however we have most of these wheels for the 1988-1996 C4 as well. If you have a 1984-1987 then their is currently only one style available which is the C4 ZR1 style.
http://shop.floridaspeedshop.com/Wheels_c22.htm
http://shop.floridaspeedshop.com/Wheels_c23.htm
MM
