School me on camming
Old 10-25-2016, 03:17 PM
McCarthy
McCarthy's Avatar
Default School me on camming
deleted by poster
Old 10-25-2016, 03:24 PM
Elite275
Elite275's Avatar
You'll get many varying opinions on this one especially in terms of preferred brands and tuning.
Originally Posted by McCarthy
I bought my 2016 Z51 A8 earlier this year, 5000 miles so far without any issue. I love the handling but I’d also love some additional 150 horses without having to deal with forced injection. I won't be tracking it but drive pretty hard when nobody is around.
1.) Can I do the camming (and headers) in my garage? Without a lift, only tall jacks?
You could, but it would be a bitch.
2.) Would it be easier to pull the engine?
Vengeance Racing pulled mine when they installed the cam.
3.) How good will the A8 be able to deal with 500 – 550 RWHP? Should I upgrade right away?
The stock A8 will be fine. With an aggressive cam to achieve these numbers you'll definitely need a converter though.
4.) What the best cams and header combo out there?
I have VR Stage II cam and TSP headers. Again, personal preference will need to be applied here.
5.) What tuner will fit the bill?
Definitely seek references here and don't be afraid to do a bit of travel to get things right the first time instead of someone using your car as a learning tool to stay local.
6.) Any good dynos around Tampa Bay?
Can't help here.
Thanks guys.
McCarthy (10-25-2016)
Old 10-25-2016, 03:43 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
Default ttt
With all the work that it will take to get to that number. More so with a big cam in the car say good bye to the MPG big time. Robert
Old 10-25-2016, 04:08 PM
McCarthy
McCarthy's Avatar
deleted by poster
Old 10-25-2016, 09:11 PM
tblu92
tblu92's Avatar
St. Jude Donor '13-'14-'15
Max HP with camming an LT1 engine depends on a couple things
IF you retain AFM you are very limited to cam choices---Even Comp Cams largest grind that is AFM friendly will limit you to about a 35-40 HP gain---These cams also require a VVT limiter kit
NOW If you chose to delete AFM--the cam choices become unlimited !!!They also require a VVT limiter kit----Texas Speed and Weapon X have cam kits that will add an easy 80 RWHP----Adding LT headers will push it to apprx 100 RWHP
And finally adding a basic set of C n C'd heads will push it to about 125 RWHP
They even have a set of better heads foe not much more $$ that will put you into the additional 150 RWHP that you seek----Plus even this max effort kit is still 1000's of dollars LESS than an installed SC kit
PS You can Google search "installing a cam on a C7 Corvette" and there are several sites thst go thru the procedure in detail----It is rather difficult as you have to remove the electric steering and many components in the front---Do-able on jack stands ?? Yes just more difficult---Deleting the AFM is somewhat complex as is installing the VVT limiter
McCarthy (10-27-2016)
Old 10-25-2016, 09:20 PM
Higgs Boson
Higgs Boson's Avatar
Received 2,379 Likes on 1,238 Posts
What about forced induction are you worried about "dealing with" vs pulling your motor, taking half of it apart, changing cam to something that is going to be louder, idle like ****, be more stinky, make less power than a blower, etc etc. A cam is a huge compromise. A cam is 20 hrs of labor. A blower is about 6.
What makes you want a cam and what makes you not want a blower?
Old 10-25-2016, 09:34 PM
Speedforhire
Speedforhire's Avatar
So you're thinking about installing a cam?
Heres my advice: GO BIG or GO HOME!
Old 10-26-2016, 12:08 AM
X25
Sr.Random input generator
Support Corvetteforum!
X25's Avatar
Received 1,465 Likes on 1,022 Posts
Well, if he goes big, he'll definitely go home, since sooner or later it will break down : )
Old 10-26-2016, 06:52 AM
davidtcpa
Go Canes!
davidtcpa's Avatar
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
I cammed my C6. but in the C7, they usually pull the motor to do it.
Old 10-26-2016, 08:56 AM
JHEBERT
JHEBERT's Avatar
Cam swap in c7z = 19hrs of knowing what you are doing, with a 2-post lift AND a means to support the short block in the car while it's in the air and the front cradle is out.
Do not skimp on valve springs and retainers, buy proven and tested
John
Old 10-26-2016, 09:41 AM
MikeLsx
MikeLsx's Avatar
a lot of work and parts go into a cam swap. After having a cam in the past, i would go with a less aggressive cam. The car will drive better, and have less wear on the valve train.
I also would never dream of doing my own work.
Kracka (10-26-2016)
Old 10-26-2016, 10:24 AM
Kracka
Kracka's Avatar
Received 5,711 Likes on 2,918 Posts
Good insight here. My previous experience with aftermarket cams in an engine was fairly similar, which is why if I cam this car, it will be a very MILD one. In a previous car I installed aftermarket cams on, the idle quality was terrible, cold starting was rough, and it loved to die with the A/C on.
I had no idea installing a cam in these cars was so labor-intensive. I was thinking I'd be doing myself a favor going for a cam or a cam/heads setup vs. just adding a Procharger kit and living happily ever after
Old 10-26-2016, 12:28 PM
Higgs Boson
If you had driveability issues like it dying then you need a better tuner....
Speedforhire (10-27-2016)
Old 10-26-2016, 12:39 PM
dfettero
dfettero's Avatar
Get a tent and sleeping bag. Could not resist!
Old 10-26-2016, 01:45 PM
Kracka
Kracka's Avatar
Completely different platform and very large cams.
Old 10-26-2016, 01:55 PM
JHEBERT
JHEBERT's Avatar
It can still be tuned, unless your running 40deg overlap on a tiny motor....proper tuning goes a long way. We can even do the opposite and make a small cam sound big. If you installed a cam and just got a dyno tune for WOT you would in fact be only about 10-20% tuned. There is so much more than timing and fueling at WOT to make it drive happy on the street. Find a GREAT tuner and pay him well, you won't regret it.
John
The following 2 users liked this post by JHEBERT:
McCarthy (10-27-2016), Speedforhire (10-27-2016)
Old 10-26-2016, 02:48 PM
Kracka
Kracka's Avatar
Luckily, I knew my way around that ECU very well, and eventually supplied my tables (which I continued to work on after the professional dyno tune) to a lot of shops and tuners once I was able to get it dialed in as much as possible
Regardless, not the point of this thread... The ECU on the C7 I have not a clue about! Not something I would attempt on my own with how complex everything has become.
To School me on camming
Old 10-27-2016, 12:00 AM
Higgs Boson
Doesn't matter. Can make snap, crackle, pop into snap, crackle, stock.
Old 10-27-2016, 12:43 AM
McCarthy
McCarthy's Avatar
deleted by poster
Old 10-27-2016, 12:33 PM
Speedforhire
John
.....with you and Higgs. The cam is exactly why I miss my C6 GS. Even though this new Z car is boosted, it just doesn't have the character the GS had. After driving both cars now I think the GS was faster.
Quick Reply: School me on camming
