Clay Bar Marring Article - Accurate?
I just came across this page, which discusses how clay bars are not "harmless" and will cause marring and swirl marks.
http://www.bugmanweb.com/c6/c6index.html
I've read almost all positive comments and results on this forum for claying. However, this article now gives me hesitation.
Any thoughts?
Thank you!
Any thoughts?
Thank you!
Umm, yes and no........
Claying helps "remove" extraneous particles from your paint that can hinder bonding of your lsp (last step protection).
Suggestions:
Get a "mild" clay, unless you have to remove stuff like overspray.
Use a good lube, and use a lot of it.
GLIDE the clay across the paint, DO NOT PUSH IT DOWN
Even being somewhat careful, you may induce some minor marring, but that should very easily polish out.
Suggestions:
2013GrandSport (10-26-2016)
A few other pointers.
After each section, fold the dirty side in on itself and use a clean section of the clay.
If you drop the clay on the ground throw it out and get a fresh piece.
When you're done, feel how smooth the surface feels.
After I clay bar the next step is the polishing process. Any marring left by the clay bar is quickly removed in the polishing process. I know people who clay only and then wax which produces mixed results especially on dark colors. Clay, polish, sealant then wax. There're are no short cuts to a great finish and shine.
The following 3 users liked this post by cmonkey713:
Former Vendor
Awesome chart KillrWheels! Now I just need to decide on the brands and product applicators for each and every step. Decisions, decisions. I am leaning toward Blackfire after seeing good reviews and Glen E's guide.
Killrwheels@Autogeek (10-26-2016)
