Wheel hop
Wheel hop
Not sure if its just cuz the car is brand new and i been driving in cold weather on summer tires, but how can i get rid of wheel hop???
This was an issue that had to be addressed on my 14' 5.0 i wasnt expecting it to be an issue in a 2017 grand sport corvette, but it sure is.
What parts need to be changed to remedy this?
What tire pressure in the rear?
Yes i am talking about wheel hop on launch.
33psi warm is that low? Thats what it said on the performance gauge inside the car. I figured it had to be right so i didnt check if it needed to be higher cuz the car is brand new.
(stock wheel and tires)
Actually. Have to double check if that was warm tire temp, i forgot if i checked it when the tires were cold or warm.
Received 7,752 Likes
CORVETTE TODAY Host
St. Jude Donor'15
It's called the Ackerman Effect. Do a search here on CorvetteForum and you can read more about it.
This is common with Corvette. Once your tires heat up, this goes away.
Actually, it's normal on most any high HP/TQ RWD vehicle on cold high performance tires.
Im talking about when you try to launch the car and instead of puttin down skid marks on the floor you get a severe vibration.
On my 14' 5.0 mustang i changed out the upper and lower rear control arms for some bmr pieces that had polly bushings, that eliminated the wheel hop 100%. I could launch the mustang on any surface at any temp and it would put all the power to the floor no hopping and skipping bs. I want that in my vette. Wheel hop is embarrassing.
Heres wheel hop if you dont know... its at the 22 second mark in this video.
I have the same issue on my 2016 Z51 and posted it here back in the spring. Never found a solution. On launch I can't get a good smooth smoky burnout, even with all the nannies turned off. Feels like the tires alternately grabbing and releasing with major vibration that I assume is wheel hop. You are not alone.
Z06NJ (12-11-2016)
I just queried "corvette wheel hop launch how mitigate" and boatloads of results followed. YMMV.
Tried to do a launch again today it was 70 degrees and tires were more then warmed up... hopped like a bitch. Temp is not the issue.
And yes i googled it, cant find any fixes for the c7 regarding to wheel hop.
Im sure It needs stiffer bushings 100% i just need to figure out which bushings.
Edit**
Im prolly just gonna swap em all out with this kit...
http://www.ridetech.com/store/2014-u...shing-kit.html
Edit**
Edit**
Edit**
Rev higher before dropping the clutch... i dont have an issue with burnouts, its when the tires are on the edge of grip when trying for a launch when you get the hop.
I was out this weekend and did some runs from a dig. 16 z51 M7. I have the pilot super sport tires in the non run flat version. So i know its not the run flat causing the wheel hop.Anyone find a solution?
