Frame Rail Rust
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
SIMPLE! The frame is STEEL and the simple black enamel paint the factory used on the frame rail is breaking down and no longer protecting the frame.
SIMPLE FIX. Wire brush the rusted area, use some spray can rust converter to kill the remainder of the corrosion and then use KRYLON semi gloss black paint to repaint the frame rail/s
Received 19,291 Likes
'20-'21-'22-'23-'24
with Bill. Steel will rust over time.
I questioned the same issue:
https://www.corvetteforum.com/forums...-enclosed.html
So this past spring I re-did mine because of a unsightly rust ...here is the link with pictures!
https://www.corvetteforum.com/forums...nted-pics.html
