★ Attack Blue Dry NANOFIBER High Flow O.E Replacement Filter (FREE S&H)
Premium Supporting Vendor
Location: ★ Performance Parts & Accessories ★ 1800 778 9898
St. Jude Donor '07-'08-'11-'12-'13-'14-'15-'16-'17
Attack Blue LT1 & LT4 Dry Nanofiber High Flow O.E Replacement Filter
ORDER NOW FOR FREE SHIPPING (lower 48)
MORE POWER, MORE TORQUE, OUTSTANDING FILTRATION!
★ Nanofiber Technology for the absolute best filtration & air flow!
★ Larger than stock design for bigger HP & Torque gains! (Huge gains for the LT4)
★ Noticeable louder, deeper sound!
★ Fits the stock air box. Drop it in & go!
★ No codes. No tuning. No issues!
★ Dry filter. No oils or chemicals!
★ Washable & reusable!
★ Does not void your warranty
★ Fits LT1 & LT4
★ Patent pending design
★ Made in the USA!
Filtration:
An important consideration when choosing your air filter is “how well does it really capture dirt”.
While allowing air to feed your engine, the air filter needs to protect your engine from harmful particulate and premature wear.
It's a fact that Nanofiber technology is key to the absolute best filtration with the least amount of restriction for the greatest volume of air. It truly is the best of both world!
Attack Blue’s Nano media efficiently traps particles down to sub-micron levels!!
Nanofibers are ultra-fine. Since the fibers are so much thinner than traditional spun fibers, you can pack more fibers in the same amount of space which creates more obstacles to stop particulate from passing through without sacrificing air flow!
Power:
Besides dropping the same old fashion media for new Nano technology, Attack Blue’s new patent pending design creates more surface area. The larger than stock filter allows more air to enter your engine. SO between this new design and our free flowing Nano media, expect HP & torque gains!
Even though the Attack Blue filter is larger then stock, it still fits in your stock air box with no modification. Just drop it in & go!
Dry, Washable & Reusable
The Attack Blue 2014-18 LT1 & LT4 filter is washable and reusable. Besides saving you money, you have the ability to run on a clean free flowing filter more often.
The media is Dry! No oil or chemicals are needed [/B] to clean or treat the filter.
No codes, No tuning. No issues!
Like it says, drop it in and experience nothing but a smooth yet responsive feel. No codes. No tuning nessessary
Louder
Don't be surprised if you LT1 or LT4 is noticeably louder, deeper stronger sounding once the AB filter is installed. (Video to follow soon)
Made in the USA! It’s completely in a league of its own!
★Click here to securely Order:
http://www.tkoperformance.com/Attack...T4_p_1051.html
Any questions, please contact us via phone 1800 778 9898 9:00am- 4:30pm est or email us anytime sales@tkoperformance.com
Thank you
New batch in stock & ready to ship.
All Orders from 11/25-11/30 Shipped!. Tracking numbers have been emailed.
Any questions please contact us! sales@tkoperformance.com
The lack of oils does set it apart from some competition and would suggest less ground for GM to void a warranty.
Do you have independent lab certification of the filters performance for removing particulates? If so, was your filter tested against the OEM filter for a baseline? This could be the only other avenue GM could exploit and having lab results showing it performed equal or better than OEM would eliminate this.
If you can share the lab's results and they show your filter meets or exceeds OEM filter performance, I'd get one.
Has there been any dyno testing? I realize that any gains will be negligible, but just curious...
the fact it's washable and reuseable makes it economical...
I'll see if i can exceed my previous record of 7.0 L/100 KM for fuel efficiency... and hope that there is a slight improvement in throttle tip in.
TKO Performance (02-08-2017)
a measureable improvment in fuel efficiency is a good gauge of the improvement i may see.
All orders that were placed from 2/15on are going, going.....GONE!
Thank you for your business
Ed
Ed
1800 778 9898. We do have them in stock.
No tune. No code problems.
Its for the Stingray & GS - LT1
and the Z06- LT4
Ed
How do you clean it? And how often?
Has anyone tried this filter? any reviews?
