Replacement cap for GM Opti
Any new favorites pop up in the sea of conjecture? My coil socket is a little chipped, hoping dielectric grease will keep it sealed? Seems crazy to spend hundreds just for the cap?
I would not worry about it.
I purchased a Standard Motor Products cap and rotor a couple of years back to put on one of my backup used optis. It seemed to be heavier duty than the factory cap and should do the job.
Link -https://www.amazon.com/Standard-Motor-Products-DR473-Rotor/dp/B000C7WVK8
Had to edit prior post. I put in the wrong link.
I you haven't taken the balancer pulley off before, make sure to put anti-seize on the mating surfaces when reinstalling. It will make it much easier if it has to come off again in the future.
If you say so.
You do but it is not a balancer. If yours is running just loosen the bolts and soak it then start a few times. Or get under it and use a brass drift or a 1 by and tap and turn. Do not hit the outside of it. It will fall off 20 minutes after your arm does. locktight the cap and rotor anti the pully.
