Any pictures of 17x9.5 all around
looks like im going for the OE replica Y2k Wheels for the C4 and was recommended 17x9.5 275/40/17 all around. Seems to be a logical choice of function over form.
Does anyone have pictures of a similar setup? At the minimum id be curious to see what the stance looks like with a 9.5 width and 54mm offset.
Thanks in advance !
Thanks in advance !
Thanks in advance !
Thanks in advance !
NiteriderFRC (12-04-2016)
Thanks in advance !
Thanks in advance !
Don't have pictures of the Y2K wheels, but the stance and fit should look like stock placement.
The '89-'96 17" x 9.5" wheels have a 56mm offset so all the '89 to '92 and optional on the '93 -'96 have the fit for you to compare. (The 56mm stock to the 54mm you referenced is only 0.08" different so I doubt you could tell the difference.)
The C5 17" front wheels were 8.5" with 56mm offset (the rears were 18" x 9.5" 65mm offset). Aftermarket could be anything so make sure what you are getting.
Good luck.
Good luck.
thanks for the info guys!!!!
I have the 17x9.5 275/40/17 all around. Buit my offset is 38mm made especially for the 84-87 so no spacers are used.
I hope this helps.
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
