View Poll Results: How Do You Use Your A8/A6?
Auto most of the time. Paddles occasionally
44
65.67%
50/50. Mix it up and use both frequently
12
17.91%
Paddles most of the time, and auto once in a while.
9
13.43%
Auot for teh stree and paddles for track work
2
2.99%
Voters: 67. You may not vote on this poll
A8/A6 Owners Paddle Shifting Poll
For A8 or A6 owners. How do you prefer to shift?
* Mostly let the transmission shift itself. I use paddles very little.
* Mix it up about 50/50. Sometime I use paddles other times I use Auto.
* Use the paddles most of the time and I only use auto occasionally.
* Auto shift for street and paddles for track work.
* Use paddles exclusively. Never use auto. (should have added this to the poll)
OLD_GOAT (12-03-2016)
I don't like the paddle setup on my 2016. With my daughters Mini I liked the more intuitive system. With either paddle you pull back as you accelerate, push forward as you decelerate. In other words natural for your body's momentum. I don't even use the Vette's paddles at all.
I couldn't vote, because I never drive in D. I use the paddles exclusively.
Scruff Vette (12-03-2016)
I use M mode more and more. I really like controlling which gear I am in, but I don't miss using my left foot to do it. When in M mode, if coming to a stop I let the computer do the down shifts. Around corners I do the shifting.
CF Senior Member
I use the paddles almost exclusively. They add fun to the driving experience, provide great exhaust sound and avoid the annoying AFM. Like driving with a manual but without the hassle of a clutch.
Received 2,639 Likes
At first I used auto most of the time, but as time goes on I find myself using the paddles more and more. My car is one of these famous "warblers", and using the paddles I can keep the engine out of the "warble cruising range" of 1500 rpms. It stops that nasty noise in it's tracks.
https://www.corvetteforum.com/forums...asionally.html
No way would I use any paddle shifter at the strip. There is too much 'lag' time from hitting the paddles and the car actually shifting.
I may occasionally use the paddles, but when I mean business about getting a good slip, I let the car shift itself. None of us can shift faster than the computer.
