Vapor canister interchange?
Old 12-04-2016, 04:45 PM
Saddlehorn
Saddlehorn's Avatar
Default Vapor canister interchange?
Pulled the vapor canister out of my '73 and was wondering if anyone has used a '74 or later vapor canister in their pre-'74 vette? If so, any line hookup differences? Saw article on replacing the charcoal, but just plugging in a later year canister looks easier than trying to 'glue the old canister back together - and safer, I'd assume. Thanks for any input.
Old 12-04-2016, 05:15 PM
MajD
MajD's Avatar
Check out this thread...I believe Tooch1 also has a 73. It looks like the bottom pops off with a screw driver, so you should be able to change the charcoal and filter and shouldn't have to glue anything back together.
https://www.corvetteforum.com/forums...-question.html
Good luck.
MajD
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi S,
I think the determining factor may be the number of 'pipes' on the top of the canister you choose as a replacement.
For instance 70-72 canister tops have the line from the separator on the side of the tank, and then two lines running to the carburetor.
I think your 73 has 3 pipe/lines also?
I believe some later canisters have just 2 pipes?
Regards,
Alan
When you pop off the bottom it gives you access to the fibrous 'pancake' filter, but not the charcoal itself.
Saddlehorn (12-04-2016)
Old 12-04-2016, 05:18 PM
MajD
MajD's Avatar
Never mind...I see it looks like the second filter screen has to be cut out to get to the charcoal. Sorry about that.
MajD
Old 12-04-2016, 05:28 PM
Saddlehorn
Saddlehorn's Avatar
MajD
Thanks - appreciate the response. It does look like I'll have to cut the old one open to replace the carbon. Have heard of folks using JB weld epoxy and/or super glue to glue the canister back together. If the canister is polyethelene, then not many glues will work well.
Old 12-04-2016, 05:39 PM
Alan 71
Alan 71's Avatar
Hi S,
Member CraigH from Australia posted a thread in which he gives instructions and photos showing how to replace the charcoal in the canister.
Regards,
Alan
https://www.corvetteforum.com/forums...-canister.html
Click Craig's link in post #3.
Old 12-04-2016, 07:12 PM
DUB
DUB's Avatar
Received 2,713 Likes on 2,321 Posts
Odd question,
Why do you feel you need to replace the charcoal??
DUB
Old 12-04-2016, 09:56 PM
Saddlehorn
Saddlehorn's Avatar
Originally Posted by DUB
Odd question,
DUB
Noticing a gas smell in garage, but not bad. The canister is original but the car was stored for many years before I got it. Possible the carbon is still OK? I checked to see if the gas odor was coming from the vicinity of the gas tank, and it is not. Gas tank is new and the 'vent' device on the tank top (side) was replaced at the same time.
Old 12-05-2016, 08:16 AM
Alan 71
Alan 71's Avatar
Hi S,
I believe I'd check that the fuel separator on the side of the gas tank is actually in working order, and that the hose connections at the top of the canister and at the carburetor are correctly run.
If the 2 hoses running from the canister to the carburetor aren't routed properly, and to the correct ports on the carburetor, the vapor which has attached to the surface of the charcoal charcoal won't be drawn into the engine to be burned.
If there is an excess of vapor (more than the charcoal can store) the vapor is vented through the bottom of the canister. That's why some folks begin by replacing the pancake filter which is easy/inexpensive to do.
These can all be done before resorting to replacing the canister or the charcoal in the canister.
Regards,
Alan
Old 12-05-2016, 09:08 AM
Tooch1
Tooch1's Avatar
Having just gone through all this with my 73 ( see my previous posts), recheck everything, especially the hoses going to the canister. You state yours is original, make sure the hoses aren't dry rotted or cracked. My original hose 'yellow stripe" connecting the canister to the metal line going back to tank was cracked. But I couldn't see that until I crawled under the car. It looked ok up top. But it was bad at the clamp connection. My previous posts on here show how to change the lower filter. Another place to check for leaks, even though you say you have a new tank, is around the filler neck. Pull up your rubber boot back there and check the gasket area where the filler neck is attached to the tank. My car had a new tank installed too by the previous owner, but two of those little screws connecting the neck to the tank had the rubber seal washers missing and I was getting some seapage around there. Just saying!
Hope this helps,
Jimmy
Old 12-05-2016, 11:45 AM
Saddlehorn
Saddlehorn's Avatar
Originally Posted by Alan 71
Hi S,
Regards,
Alan
Alan - good input. Found the line from the carb port on the canister was hooked up to the window washer of all places!! Where on the carb does this go - to a port on the carb to manifold base or to a port toward the upper portion of the carb. I have later (electric choke) model Qjet on the car. Finding numerous vacuum hose routing issues with the canister hoses. The PCV hose is connected directly to the intake manifold fitting, so more work to do here. May ask for more help on proper routing as my AIM is really fuzzy on these hoses. Thanks again for getting me on the right path.
Old 12-05-2016, 11:48 AM
Saddlehorn
Saddlehorn's Avatar
Hope this helps,
Jimmy
Thanks - I'll be checking those areas today. Really appreciate the input as the Corvette has been a real learning experience for me.
Old 12-05-2016, 12:05 PM
Saddlehorn
Saddlehorn's Avatar
Another question - what type of line did you use to replace the 'yellow stripe' line to the gas tank? Just fuel hose from the auto parts store? Thanks.
Old 12-05-2016, 12:13 PM
Tooch1
Tooch1's Avatar
Here are a couple pics showing where my 73 hoses coming from the EVAP canister go. The larger one coming off it comes up to the pcv valve as marked on the top of the canister. Then it goes to the lower right side port on the carb. Attached with a clamp. The skinnier ribbed white stripe hose follows the same path, and connects to the lower port on the left side of the carb as shown. I used a replacement hose for now to connect the canister to the metal fuel vent line going back to the tank. It must be for fuel. They are made different (stronger) than a vacuum hose. However, all the vendors sell the hose and clamps. But it doesn't have the stripe. Original clamps for the larger hose are yellow, and red for the smaller hose coming off the canister.
Regards,
Jimmy
Old 12-05-2016, 12:14 PM
Tooch1
Tooch1's Avatar
EVAP hoses to carb.
Old 12-05-2016, 12:16 PM
Tooch1
Tooch1's Avatar
Another view. This shows where the large hose goes. Hope these help!
Tooch
Old 12-05-2016, 12:24 PM
Alan 71
Alan 71's Avatar
Hi S,
The small diameter hose (white stripe in 71) runs directly from the canister nipple to the carburetor while the large hose runs from the canister to a 'T' at the PCV valve and then on to the carburetor.
Regards,
Alan
Here's an overall view to go with tooch's detail views.
Saddlehorn (12-05-2016)
To Vapor canister interchange?
Old 12-05-2016, 03:44 PM
Saddlehorn
Saddlehorn's Avatar
Tooch
Thanks Jimmy - this really helps. My canister was obviously not connected correctly. I think every hose needs to be rerun.
Old 12-05-2016, 03:50 PM
Tooch1
Tooch1's Avatar
No problem,
Let me know if you need anything, if I can help I'll be glad to. I can't imagine having that hose hooked to the wipers
Tooch
Old 12-05-2016, 05:21 PM
DUB
DUB's Avatar
Thank you for answering my question on why you want to mess with the charcoal canister.
From experience working on these old Corvettes.
DO NOT assume that your metal vapor return line that runs parallel with your brake line on the frame is in good condition. I have lost count with how many EVAP systems I have repaired where the steel line was rusted out and actually had a split in it. Or it was plugged up and the vapor line was useless.
I would get the hose off BOTH ends of this line and see if you can blow air through it. IF you can...so far so good. The the next test is to plug one end of the line and using hand vacuum pump...pull a vacuum on the line and make sure it holds vacuum. Because if it does NOT hold vacuum...you have a problem somewhere in the line that needs to be replaced. Or you will still have fuel vapor smell in the garage.
DUB
Quick Reply: Vapor canister interchange?
