Headlight Door Hinges
Attempting to replace the headlight door hinges on my 71. I've loosened the 3 hinge bolts on both sides of door. Adjustment hinge spacers loosened. I would think the door would slide to either side to come out if it's sockets. But I can't seem to slide over enough to remove. Am I missing something?
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Hopefully this will help you.
Headlamp Housing Adjustment 68-82
Yep....I figured that also. However in order to get old bearing out I need to move light housing to move or slide to l or r. For either bearing. Just can't seem to move over enough to got to out of its housing socket. Headlight door don't only pivot on bearings. There is a hole behind bearing/hinges that door bracket plugs into. I'll try to get pic tomoro.
Former Vendor
You have to loosen the spacers up.. remove the three bolts from each side and then slide the housing to one side, remove the bearing, then slide it the other way and remove the other bearing.
Willcox
Willcox
Former Vendor
go to the 4.08 mark.. you'll see the spacer that I'm talking about.. They have a allen head screw and you loosen these up on both sides.. then you can move the door lateral to remove it from the bearing... And... Sometimes the bearings are stuck to the pivot, so you may have to get brutal... just be careful, the housing is pot metal and will break easy.
Former Vendor
No worries.. you get stuck, message me at support@willcoxcorvette.com
