HELP!!! Dash problems gauges/dash turning off while driving
Backstory
This problem started happening right after ecs 1500/longtubeheaders/alky/tune install
At first I was getting a service battery msg at random times it would go on and off
Then that stopped now my dash and gauges turn off at random while driving but car still runs good
I'm scared to take it to dealer , because I don't want them messing up my tune and alky control . Today I had a friend that owns a shop run my codes and try to figure it out
These are the codes i had
Received 1,762 Likes
ttt
Call ECS and see how they wired the meth into your car. Most shops will do wiring the same way all the time, That way it is like a one step thing.
If they didn't wire into nothing that works the dash wiring, I really don't see that from the meth install, plus sure not from install of the LT headers. I would take it into the dealer tell them headers and the meth was added. To please look at under warr work and for sure not to mess with the tune on the car. Robert
KostaT26 (12-07-2016)
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,084 Likes
We do all the meth wiring in the back of the car, take the rear cover off and see if anything looks loose. Of course you're more then welcome to come here anytime at your convenience and we'll take a look for you.
Also take a look at the fuse box to mounted properly, that has to get removed when doing headers.
So my battery is good had it checked with my brights on ac up and rpm at 3-4K my alternator showing 15.5 16 the guy said that the alternator is overcharging my battery? Is that normal with a supercharger or supercharger doesn't effect alternator charging ? Possibly need new alternator ? At 10k miles
Platinum Supporting Vendor
I would look for a loose ground wire. Check the grounds that hooks to the frame on the driverside just in front of the electric vacuum pump. I've seen a few guys leave one of those loose and cause weird electrical gremlins.
KostaT26 (12-08-2016)
I checked all the grounds on driver side and passenger side frame inside engine bay took out the fuse box and everything around it to check the grounds underneath grounds inside car and back of car all harnesses and grounds all wires around headers everything is nice and tight and not melted ..... I found one harness underneath my headers by oil filter that prolly went to an 02 sensor I'm guessing it doesn't reach to anything I can see visible that can be plugged in (pic attached)
ttt
Rear r front 02 sensor hook up you are correct. from above statement on the ground did you play with the ground wires to make sure not loose. Like really made sure the nut is really good and bolted down.
If you can't figure it out I would remove the meth kit connections to your cars power and see if you can still replicate the issue. Can you replicate with out full throttle? If you are tuned for meth don't go wot with out it
Update changed my alternator and car is charging normal now drove about 100 miles today with no issues. Voltage regulator in alternator went bad I guess at 10k miles.... idk why it would go bad that early. I'm thinking the heat from my long tube headers. THinking about making sone kind of heat shield for the back of the alternator to prevent from new one going bad
