High flow cats
Received 19,226 Likes
'20-'21-'22-'23-'24
I believe Random Technologies makes them - you cut the old ones out and weld the new ones in. Not sure if you have to do anything else though. Someone else that may have switched to them can answer that.
Are you looking for the OEM or a replacement? Replacement I used MagnaFlow.
I'd say if your car is stock, there's no real reason not to use OEM replacements. On the other hand, if you're putting on headers and all the rest, it's worth the cost of upgrading the cats, too. I used Random Technologies cats. They do flow a little better, and on a modified car, the little things add up.
OP, why are you wanting to replace them?
Thanks I was looking increase the hp with mods & a tune all while sticking with the original exhaust to keep the dd drivability
Thanks vetteman I looked into them & seems they went out of business
