Fuel pressure regulator diaphragm positioning...
Old 12-07-2016, 11:48 PM
racerseks
racerseks's Avatar
Default Fuel pressure regulator diaphragm positioning...
Installing a new fuel pressure regulator on a mostly stock '86 and it's already off the car. There's the regulator/diaphragm itself, the cap, and a ring with part number RP80182 on it. The ring has a lip on it, and just like to be sure if the lip faces up or down...and also, does the ring go between both gasket pieces of the diaprhagm? Thank you.
Old 12-08-2016, 05:34 AM
antfarmer2
antfarmer2's Avatar
94 here so do not know. But there was a bad run of those make sure the metal button in the center is polished and smooth.
racerseks (12-08-2016)
Old 12-08-2016, 09:19 AM
Joe C
Joe C's Avatar
the inside edge of the ring is beveled to somewhat match the radius on the regulator's cap. it should be installed with the "lip" in the up position as shown. it does not go between the rubber gasket pieces of the diaphragm. here's a pic of how it should be assembled -
Old 12-08-2016, 11:38 AM
racerseks
racerseks's Avatar
Thanks for the heads-up. My replacement seems polished, though not quite as much as the original. Any other indicators? Thanks again!
Old 12-08-2016, 11:41 AM
racerseks
racerseks's Avatar
Thanks for the info and pic! Just to be clear, from the base up, it should go diapraghm (both layers) ring with lip up, and then cap. Is that correct? Again, thank you!
Old 12-08-2016, 12:01 PM
antfarmer2
antfarmer2's Avatar
Should be ok then the bad ones you could hang a fingernail on.
racerseks (12-09-2016)
Old 12-08-2016, 01:23 PM
Joe C
Joe C's Avatar
from the base, diaphragm (both layers), then the cap, and finally, the ring (lip up).
racerseks (12-10-2016)
Old 12-09-2016, 02:00 PM
racerseks
racerseks's Avatar
I gotcha! Thanks again!
Old 12-10-2016, 12:30 AM
racerseks
racerseks's Avatar
Okay, thank you!
To Fuel pressure regulator diaphragm positioning...
Quick Reply: Fuel pressure regulator diaphragm positioning...
