C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] New Jessel pedestal rockers at PRI
Old 12-09-2016, 11:36 AM
phipp85
phipp85's Avatar
Default New Jessel pedestal rockers at PRI
This might interest some here as another rocker option. Guy said they have been out about a week. Steel body.
The following 2 users liked this post by phipp85:
Bad_AX (12-09-2016), MTPZ06 (12-09-2016)
Old 12-09-2016, 11:58 AM
WhiteDiamond
WhiteDiamond's Avatar
St. Jude Donor '15
Did they mention a price? Look nice.
Old 12-09-2016, 12:06 PM
wjnjr
wjnjr's Avatar
Very interesting...Looks like they're on stock springs & valves, wonder how that would work out on the spintron? Of course this is only a display.
Old 12-09-2016, 12:16 PM
double06
double06's Avatar
Very nice. Looks like it fits inside the head where the adjuster is too. Probably fits under factory valve cover.
Old 12-09-2016, 12:43 PM
outhouse
outhouse's Avatar
spintron time and weight measured
Old 12-09-2016, 12:52 PM
lt1z
lt1z's Avatar
I am 100% sure this forum will find fault with them...
The following 2 users liked this post by lt1z:
FSTFRC (12-09-2016), Medicdiver (12-11-2016)
Old 12-09-2016, 01:18 PM
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Now we're talking...I'm liking the design.
Old 12-09-2016, 01:20 PM
MTPZ06
MTPZ06's Avatar
I'll donate to that cause...
outhouse (12-09-2016)
Old 12-09-2016, 01:25 PM
Michael_D
Michael_D's Avatar
LOL...... I've long stop giving a **** what the forum masses think. But, there are a few who actually do possess the hands on experience and common sense to give up on everyone. I hope you don't either.
Old 12-09-2016, 02:10 PM
phipp85
phipp85's Avatar
Jessel said they really aren't cost effective for our intended use. They are geared towards class racing that mandate use of stock mounted rocker systems. Looking at $2800 or so for these. Might as well go full shaft mount at that price.
They do look fancy though.
Old 12-09-2016, 02:24 PM
MTPZ06
MTPZ06's Avatar
That's a pretty penny...but maybe they get into the hands of retailers and speed shops to drive the price down a few hundred bucks under MSRP...and I bet there is still a market for those that would prefer the idea of a shaft mount setup; but don't want to pull the heads to go through the time and expense of machining the heads for the shaft mount setup.
Make no mistake though, with big aggressive cams, shaft mount is the way to go IMO...these are still a great option for the bolt on crowd running a stock to mid-range cam.
Thanks again for posting these up...
Old 12-09-2016, 04:01 PM
phipp85
phipp85's Avatar
I bet these will handle some pretty serious spring pressure. Weight has certainly been trimmed from the nose area, nice piece for sure.
I agree they have a place in the market. Not everyone is willing to yank the heads off for the extra machining required with full shaft system. I recently pulled my head(blown head gasket) and found some unpleasant hourglass wear patterns. I'll be going to some sort of roller tip rocker most likely. I'll try and post a thread about it in a few days.
Old 12-09-2016, 04:23 PM
phipp85
phipp85's Avatar
Here's the "I hate money" rockers lol. $3900
Old 12-09-2016, 04:49 PM
MTPZ06
MTPZ06's Avatar
^^ Precisely what I would run if my build needed a shaft mount setup.
Old 12-10-2016, 05:57 AM
harveyjl
harveyjl's Avatar
these are the ones I have for my exhaust rockers and I run the pro aluminum for the intake
Old 12-10-2016, 06:40 PM
meinersk
meinersk's Avatar
ok...i think im about to buy shaft mounts any suggestions with a good price? Like under a 1.000.
Old 12-10-2016, 07:07 PM
stefuel
stefuel's Avatar
Probably get in a argument over this but technically this is not a "shaft" mount rocker setup. That said, for a LS7 this is probably better then a real shaft mount as it has no offset rockers which I've always thought sucks.
To New Jessel pedestal rockers at PRI
Old 12-10-2016, 10:26 PM
phipp85
phipp85's Avatar
Why don't you run the same for both? I'd love to have that rocker setup but I don't think I can shell out that much money without switching to a solid roller to take full advantage of it.
I think Yella Terra's are the only option under $1K. 6670 series I believe. Might want to call and verify that before you order. They have two versions.
Why do you say that? Because it's not on a single shaft?
Old 12-11-2016, 01:23 AM
harveyjl
harveyjl's Avatar
Crower Stainless steel are a very good rocker. and arnt much over 1K
Well, there is no reason to have a billet rocker on the intake. I do that so I can to keep weight off the intake valve, It wouldn't be much weight but there is extra weight the valve train has to move. I put a billet exhaust rocker because it opens against cylinder pressure. being my car is a TT set up the exhaust sees a lot of cylinder pressure.
Old 12-11-2016, 01:17 PM
lt1z
lt1z's Avatar
So you want shaft mount rocker or rockers under $1000? Lol
Quick Reply: [Z06] New Jessel pedestal rockers at PRI
