Sponsored by: GEM Motorsports
The 3+ month hibernation begins :(
Old 12-10-2016, 07:33 PM
Z06NJ
Z06NJ's Avatar
Default The 3+ month hibernation begins :(
N/a
skipperC7 (12-20-2016)
Old 12-10-2016, 08:32 PM
AZDANZ06
AZDANZ06's Avatar
Thank God I live in Arizona, drive year round!!!
Firemedic301 (12-11-2016)
Old 12-10-2016, 08:59 PM
Larry M
Larry M's Avatar
Yeah it was pretty damn cold this morning in NJ
Your garage floor looks awful, might want to consider some RaceDeck tiles, epoxy floor coating with polyurethane top color coat, or a metallic epoxy with a polyurea top coat
Old 12-10-2016, 09:12 PM
oldC5
Support Corvetteforum!
oldC5's Avatar
Received 1,226 Likes on 734 Posts
Buy yourself the extension for ctek so you can lay ctek flat on brick wall only 7 dollars amazon.
Old 12-10-2016, 09:22 PM
jpbls
jpbls's Avatar
Had my Z out today,was 34 degrees.Takes a good 20 mins for the tires to somewhat warm up.Had a couple nice runs.Not putting it away till the first sanding happens
Old 12-10-2016, 09:41 PM
mdz06vetter
mdz06vetter's Avatar
St. Jude Donor '05-'10-'11-'12-'13-'14-'15
22 degrees here in the Repunlik of Maryland
Old 12-10-2016, 09:56 PM
LowFlight
LowFlight's Avatar
St. Jude Donor '03, '17
Senior Member
Cruise-In V Veteran
So sad
Old 12-10-2016, 10:01 PM
crusher1
crusher1's Avatar
I bought the 8ft extension cable for mine a few years back...Works great.
https://www.amazon.ca/CTEK-56-304-Co.../dp/B00ADIHUVG
Old 12-11-2016, 01:10 AM
Damian M
Damian M's Avatar
I've been using an extension chord with my ctec - is that ok to be doing?
Old 12-11-2016, 02:12 AM
Larry M
Larry M's Avatar
Originally Posted by Z06NJ
Thanks for the good ideas. That might be my Spring project after I get some Tax Refund $ back!
No problem
There are a bunch of relatively simple solutions, I'd probably go with the tiles as they're slightly less expensive than doing a good epoxy job, plus you can take them with you if ever move or park your car elsewhere
Old 12-11-2016, 09:57 AM
Larry M
Larry M's Avatar
Come to think of it, I did see Costco selling those interconnecting black and white tiles some time back. I'll give those a shot and report back if I decide to move forward with them.
Before you buy the Costco stuff, check pricing with RaceDeck and tell them you're a GarageJournal forum member. They discount quite a bit to where it is competitive for a better product with way more options
http://racedeck.com/galleries/photo-gallery/
Old 12-11-2016, 11:02 AM
phantasms
Leeds.io
phantasms's Avatar
St. Jude Donor '14-'15-'16
There are other ways my friend...
Old 12-11-2016, 12:41 PM
rbartick
rbartick's Avatar
Location: Admit Nothing, Deny Everything, Make Counter Accusations.
You would be better off charging the battery from under the hood.
Old 12-11-2016, 03:12 PM
crusher1
crusher1's Avatar
Yes no issues
Damian M (12-12-2016)
Old 12-11-2016, 03:14 PM
crusher1
crusher1's Avatar
Thank you for the suggestions. However, I can't see how the extension will plug in since I don't have the US CTEK3300 unit. I'm not sure what model that is in my pictures (I'll have to look at the manual that came in the box tomorrow.) It seems that both ends are hard wired into the unit.
The only other thing that I can think of is maybe where the cigarette end adapter plugs inside the car...maybe that comes apart to allow me to connect the extension? I'll check in the morning.
Otherwise, do you know if I can just use a "regular old home" extension cable?
the unit you have is a Ctek. you just has the corvette logo on it
Old 12-11-2016, 03:35 PM
23/C8Z
23/C8Z's Avatar
Received 5,760 Likes on 3,176 Posts
OP, like others have said get an extension or charge from under the hood. just for the convenience of it i hooked up my battery tender under the hood to the fuse box and it's a one second plug in and walk away deal. good idea with the tire cradles and glue traps as well. my garage is climate controlled so hopefully when i get an unwanted visitor out there (which i have in the past) they stick to under my work benches (i also have traps, glue boards and ultrasonic in the garage) as it's a constant 68f degrees or so year round in there!
in the pic i posted you can see where i hooked up the negative and the positive terminal goes under the fusebox cover with the quick disconnect to the battery tender to the right.
I like it so there's no crushing of the wire or gasket in the hatch and it's a secure connection unlike alligator clip style which if someone bumps into the wire it can get knocked loose, off or god forbid short something.
Yes i'm OCD (and proud of it)
The following 2 users liked this post by 23/C8Z:
skipperC7 (12-20-2016), Z06NJ (12-11-2016)
Old 12-11-2016, 03:40 PM
Jakeman11
Jakeman11's Avatar
Put mine into storage last Saturday. Will be away until April. Snowing out now with maybe 6 inches on the way tonight.
To The 3+ month hibernation begins :(
Old 12-11-2016, 09:39 PM
MerakiAutoworks
Supporting Vendor
MerakiAutoworks's Avatar
No way I can do this..
Unless the car was on jack stands making huge changes.
Good luck!
-Josh
Old 12-12-2016, 01:14 AM
Larry M
Larry M's Avatar
Just got home from the Z Giants Cowboys game.
Damn it's starting to get cold, my feet were frozen most of the game. I kept sneaking out and walking to the Giants store that was warm
Old 12-20-2016, 08:35 PM
nvydvr
nvydvr's Avatar
Y'all need to migrate to Florida for the winter :-)
Z06NJ (12-22-2016)
Quick Reply: The 3+ month hibernation begins :(
