Passenger seat stuck full forward
Old 12-11-2016, 12:55 AM
460HP-YLO-JAKT
Support Corvetteforum!
460HP-YLO-JAKT's Avatar
Default Passenger seat stuck full forward
My 2015 Stingray passenger seat is stuck full forward with seat back tilted and nested against sunvisor. Seatbelt is free and pulling manual seat back lever is no help. Switches will not do anything. I did a search and read connector has to be disconnected to reset sensor. There was a picture but it didn't say if it was under carpet underneath seat or going up back wall behind seat. Anyone have a better description or picture to guide me through this?? Thanks.
Old 12-11-2016, 01:14 AM
ExRedRacer
ExRedRacer's Avatar
Received 1,029 Likes on 549 Posts
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Did you try to raise or lower the lever on the side of the seat that normally allows you to pull the seatback forward?
I had a similar experience last week and that worked for me. The switches started working once I did that.
460HP-YLO-JAKT (12-11-2016)
Old 12-11-2016, 01:15 AM
Rooster OG
Rooster OG's Avatar
Received 1,694 Likes on 1,240 Posts
St. Jude Donor '15
If the seat back is tilted forward the switches won't work. I'm a little confused by your description. Can you put the seat back and locked into place?
Old 12-11-2016, 01:21 AM
460HP-YLO-JAKT
The seat is full forward, seat back is tilted forward electrically and nesting against sun visor, so lifting manual release does nothing because seat is locked and can't go any further forward. Switches do nothing!!
Old 12-11-2016, 01:50 AM
Rooster OG
Rooster OG's Avatar
St. Jude Donor '15
If the manual release is lifted, the switches won't work. Is there anything under the seat, a water bottle or something that's wedged in there? There's a limiter switch under the carpet on the back wall, but that just limits the seat from traveling too far back. I suppose you could lift the carpet and unplug it.
I wish I could think of more things to try.
Old 12-11-2016, 01:47 PM
460HP-YLO-JAKT
Nothing under the seat. I'll look into limiter switch. I sure hate thinking about having to take to dealership and argue about it.
Old 12-11-2016, 01:56 PM
Toombs
Toombs's Avatar
If the seat is obviously stuck, I am not sure what they could argue with you about. Good luck.
Old 12-11-2016, 02:12 PM
460HP-YLO-JAKT
Warranty item discussion!?!?
Old 12-11-2016, 02:20 PM
Foosh
Foosh's Avatar
Received 16,668 Likes on 8,311 Posts
As Rooster said, it sounds like the manual seat back latch is not fully latched. Can you lift the lever and try to pull the seat back fully into the latched position?
Old 12-11-2016, 02:34 PM
owc6
owc6's Avatar
Received 4,186 Likes on 2,679 Posts
[Mine did this once time when i was looking for an earring. I ran the seat forward and it stuck. I ended up pullng the seat bottom back with my hand while I ran the switch, and it came unstuck.
Old 12-11-2016, 03:42 PM
460HP-YLO-JAKT
It's tilted forward electrically and resti ng on visor. Lifting lever and pulling on seat towards back does nothing.
When doing problem search, someone had posted a picture from 2014 for a connector to unlock and reset sensor but I couldn't tell which carpet he had lifted or where it was located. He has not answered my PM. Thread was a couple years old. Makes me think there is a limit switch that needs to be reset somehow.
Old 12-11-2016, 04:10 PM
Steve_R
Steve_R's Avatar
Received 3,289 Likes on 1,399 Posts
St. Jude Donor '12-'13-'14-'15-'16-'17
It's under warranty. Get it fixed.
Old 12-11-2016, 04:24 PM
Boiler_81
Boiler_81's Avatar
A friend had this happen to his 16. The problem was the rear travel switch was stuck. The seat could go forward but it would not go back. It was fixed by just pulling the carpet away from the bulkhead. This released the switch and it has worked fine since.
The following 2 users liked this post by Boiler_81:
460HP-YLO-JAKT (12-11-2016), smbsocal (08-01-2017)
Old 12-11-2016, 06:48 PM
460HP-YLO-JAKT
UPDATE:
I just tried it again and also wiggled wiring. Finally got seat to move back but not as far was it would normally be. The switch that controls the seat back only went back to 90 degrees and now nothing. It's much better than it was, so when weather permits, I'll take it to a dealer. Something is going bonkers with the switch assy on side of seat being it's intermittent. Thanks to all of you good forum folks for helping out on this one. Hopefully I can do same for you sometime.
Foosh (12-11-2016)
Old 12-11-2016, 08:52 PM
trakmnky
trakmnky's Avatar
Sounds like you need to stop giving rides to all those little people!
Old 08-01-2017, 03:02 PM
smbsocal
smbsocal's Avatar
I am so grateful for this thread. I thought I had to bring the Vette to the dealer to fix the seat mechanism. Luckily just a tug on the carpet behind the seat and it was back to normal.
Torque Obsessed (11-28-2020)
Old 08-01-2017, 08:49 PM
Boiler_81
Boiler_81's Avatar
Great!
To Passenger seat stuck full forward
Old 11-22-2017, 05:23 PM
Hib Halverson
Pro Mechanic
Pro Mechanic
Hib Halverson's Avatar
Received 1,141 Likes on 597 Posts
I just ran across this f'ing problem with an 18 GS I'm road testing. Why in the heck the fore-aft adjustment is locked out aft when the seat back is unlocked has me baffled.
We wanted to stick some camera gear behind the seat but we left the seat back unlocked and fooled around for 20-min trying to diagnose the problem. Then I looked here and, once again, the CF saved my ***.
Old 03-31-2019, 04:46 PM
Dphillipsc6
6th Gear
Dphillipsc6's Avatar
Default C7 seat
My C7 is a 2014 and I returned from dinner and seat would only go forward. I read this review and went back out and looked. Yep, my seat belt was keeping the manual seat release raised a little. Moved the seat belt and I got all my power buttons back. Thanks corvette forum
Old 04-02-2019, 08:39 AM
us3rname
us3rname's Avatar
This happened on my drivers seat. it worked fine after I punched the seat back towards the back of the car.
Quick Reply: Passenger seat stuck full forward
