Rear outlet battery tender
So I read here that the cord does not get punched if you close the rear hatch. I opened it the other day after about 2 weeks. The wire definitely has deep indentations. I saw that some people say to close it to the "first" latch. I have a 2016 and it pulls the lid closed on its own. How do people with the auto hatch pull down do this?
Received 1,694 Likes
St. Jude Donor '15
Don't slam it shut. You can gently lower it so the latch doesn't auto close.
I have a 16 and I just put a micro fiber towel underneath and flatten out the cord and shut the hatch. Stays like that all winter and have not had a problem with the cord being pinched.
Received 7,752 Likes
CORVETTE TODAY Host
St. Jude Donor'15
I have mine hooked up. I did not completely close the hatch. After 10 minutes, the light goes off anyway. No issues and no wire indentations.
DAC17 (01-01-2017)
Received 3,288 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
Electrical wire isn't like a garden hose; bending it won't slow down the electrons.
The following 4 users liked this post by RipcordZ51:
Do you see deep indentations in the insulation when you do this?
Last edited by Steve Garrett; 01-01-2017 at 02:49 PM. Reason: Merged Posts-please use the Multi-Quote button (middle icon) in the lower right hand corner of each post to make your response look like this.
I'm sure you can find a way to damage the cord if you close it near the latch mechanism or at the sharp edge of the hatch or trunk.
I've been closing hoods and trunks for decades over battery maintainer cords including with my C7 and have never damaged a cord.
Received 8,917 Likes
Bill
blkvet6 (01-21-2017)
The cord between the charger and the plug that goes into the rear inside receptacle is ok when you close the rear hatch. If you are putting the whole charger inside the car and trying to run the A/C electrical cord from the charger to the outside of the car, that cord is likely to be too fat to close the rear hatch without causing deep indentations in the cord. The base charger should be on the outside of the car.
I have used several chargers on several Corvettes over the last 5 years with no problem routing the small cord between the charger and the plug thru the closed hatch, in fact there are two Corvettes in my garage as we speak on chargers.
The following 2 users liked this post by Steve_R:
jimmie jam (02-28-2017),
Maxpowers (01-01-2017)
snappy2u (02-28-2017)
Slam it shut. It's fine...
CORVETTE TODAY Host
St. Jude Donor'15
Dudley has a point here...you can plug the trickle charger into the rear receptacle. Lower the driver's side or passenger window slightly and run the cord out the window. Then, you'll have no issues with cord crimping.
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,810 Likes
2015 C7 of the Year Finalist
Well Dedley and you both have a point as long as we're not talking about a convertible and are discussing the coupe.
I use the front magnetic hook up and don't crimp crap.
I hook my battery maintainer up inside the engine bay.
This is the magnetic connection:
https://www.corvetteforum.com/forums...ry-tender.html
Most just gently close the hatch or trunk on the cord. Personally, I HATE to squeeze an electrical cord for ANY reason especially for extended periods of time. Were I to store my car for the winter, I would do this: http://www.ls2.com/forums/showthread...hlight=battery
As it is, I live in Florida and drive the car year round. I still slap the car on the C-Tek when I park in the garage. I just like to have the battery topped off at all times. There are a lot of days where I do nothing but short trips and might not get the battery fully recharged before I park it for the night.
Elmer
Elmer
Why? Dozens and dozens have reported here that it is no problem, vs. 1 person who somehow found a way to have a problem.
I slam the trunk shut on my convertible over the thin lead wire. That's the only access to the rear power port, which is the only one hot all the time. I've been doing the same thing with either the hood or trunk on all my cars for 30 years without any problems whatsoever.
If you leave a little play in the wire, then it will not get crimped/pinched. I've never had any issues with the hatch completely closed.
