Smoother Touring Mode-DSC controller or Chevy Rough Track Calibration or others?
I would like to have a smoother ride when in touring mode for attenuating those highway expansion joints/bumps/etc., and although going with non runflat tires at 30 psi has helped, wanted to see what other options may work.
Has anyone tried the Chevy Performance Parts Corvette rough surface track suspension calibration 2016 models p/n 23396303, and is it better than using touring mode at the track to tune out bumps?
Anyone try the DSC Controller for retuning touring mode so it is Cadillac smooth?
I tried setting the car in track mode and then "wet setting" but didn't find the ride any different than touring mode and it killed engine power.
Thanks for the suggestions.
Received 2,379 Likes
DSC Controller does make a noticeable difference when cruising down the highway but it doesn't help with expansion joint or pothole type hits but that is the beauty of the system, you should be able to tune it for that as well.
I seems there is a real opportunity out there for DSC and it's distributors to provide a table oriented to those that are looking for the smoothest ride in touring mode. Could increase sales.
Received 8,927 Likes
Not sure how much rough track mode smooths the ride Vs making it easier for the tires to hook up when exposed to a bumpy surface. I know I started thinking about the rough track calibration when I was at CMP in October where I was getting rear wheel spin at WOT in 3rd gear when hitting bumps on the track at two track locations. These bumps were not pot holes but raised or lowered points in the surface and the rear wheels had trouble following the pavement surface. I really couldn't see them that well but I knew when I hit them.
Bill
Bill
I don't think anybody can say for sure but my car has been in for several warranty repairs since I installed the controller. They were all related to the airbag system, exhaust, and trans and I never heard a peep about the controller. Truthfully unless you start having suspension control module issues I doubt anybody would notice. If you do have issues the throw the stock controller back in.
The following 2 users liked this post by Poor-sha:
cvp33 (01-09-2017),
Rookieracer (01-09-2017)
I have the DSC controller and have modified the touring tables for a smoother ride according to DSC's recommendations and holy crap is it smooth!!! I'm happy to share the file with anyone who wants a smoother ride in tour. It's the only table I have modified. I can also post the changes for anyone who wants to duplicate it. Cadillac smooth, no joke. Easy to adjust and tune to your liking.
I'm 110% happy with the DSC unit. The best purchase I have made for the car so far.
Uploading the new suspension tune through a USB cable.
65sohc (01-10-2017)
Former Vendor
MacMan, great work , send me your file to review it, and have you used the setting tab and gone into Zero Travel? if not do its simple
1a Make sure you are on a level surface check air in the tires driver wt on seat then follow:
1 key on
2 plug in USB
3 go into setting tab
4 press Zero Travel
5 follow dialog it will show in hex all four dampers say OK
6 thats it
1 key on
2 plug in USB
4 press Zero Travel
6 thats it
I tried to zero the travel but didn't realize the car needed to be on. I'll go back and do that.
Here is a link to the file. The only thing I modified was the shock calibration table, setting the shocks to full soft up to 15%.
https://drive.google.com/file/d/0B86...ew?usp=sharing
BEZ06 (01-10-2017)
...Here is a link to the file. The only thing I modified was the shock calibration table, setting the shocks to full soft up to 15%.
I just took a look at your calibration file, and I'm pretty sure from looking at it that I know the answer.
Do you have OE shocks, or Tractive shocks??
Looking at your shock table I see 1ma for 0%-15.6%, up to 1000ma at 100%.
As I understand it, the stock shocks are full soft at 0ma (or the 1ma in your file) - is that correct?
I believe the Tractive shocks are opposite that - with full stiffness at 0ma.
In that case your table is for the OE shocks - is that right??
Just want to make sure I can upload to my car with stock shocks!!
I haven't downloaded and saved the standard DSC file that's in my car now, so I'll need to do that before loading yours in - or, simply change my shock table to mirror yours and rename it similar to yours.
TIA
Former Vendor
on our site you will find both the tractive and mag pdts files you want the mag file. you have what i think is the stock shock not the tractive
yes they are opposite in the shock cal send me your email ill email you the files if you want from my laptop
Thanks very much!!!
TIA
TIA
BEZ06 (01-10-2017)
Former Vendor
Im sorry I did not see the attachment brilliant good job. Im attaching a modification to your shock cal table and also look at sensativity in the Gtable
i went softer globally by interpolating from 10% back to 100%
as well the sensitivity is increased you may find a better ride yet
Let me Know.
https://drive.google.com/file/d/0BxQ...ew?usp=sharing
Let me Know.
Thanks very much!!!
TIA
TIA
Former Vendor
try my updated file look at sensitivity and shock cal
Former Vendor
sorry i did not have the permissions tuned on try this
fleming23 (01-10-2017)
Former Vendor
yes first setup the what you want to log in switched inputs then send that close and go into the record. use the buttons to operate the recorder. you must stop the recording before closing or the program will crash. also to save the recording follow the prompt at the bottom of the recorder under save. then when you want to view open the recorder and play back.
MacManInfi (01-10-2017)
