450-500whp Traction issues or not really?
For anyone running these number @ the wheels, how are you dealing with traction on the street?
RomanNYC (01-14-2017)
Received 3,812 Likes
St. Jude Donor '03-'04
Down force, coefficient of friction, area of contact.
A big fat sticky tire, nothing better than a 13 inch wide contact patch of stick tire,on a car with a 50:50 weight distribution. With an aspect ratio taller than 40.this lage sidewall allows for more potential energy to be turned not kinetic energy applied to the ground.
Bill aka Et
Bill aka Et
1Willy1 (01-15-2017)
All depends on throttle management. I can be all over the road and have zero traction or I can hook and book no traction problems at all. Just depends on throttle modulation.
Just as Dave mentioned, with the right tire you can roll into it. Once you're moving and the suspension is loaded up, drop the hammer and let 'er rip. I run Toyo R888's and have no issues putting down 638rwhp without even warming up the tires.
Here is the car at a 1/2 mile event on a dirty runway surface, no prep and no burnout. A quick roll into first then stood on it.
RomanNYC (01-16-2017)
Continental Extreme Contacts here.
Leave the TC on and you are fine. I can kick sideways from a stop is I feel like scaring the passenger, but under most fun driving situations you won't be spinning.
Turn the TC off and you can spin out nice and quick.
Leave TC on? That defeats the whole point of getting a tire that has enough grip.
