zip tie mod?
zip tie mod?
Ive heard about a zip tie mod mentioned here a few times but haven't a clue to what it is.. I cant find it either when I type it into the search bar. anyone have any insight? curiousity is getting the best of me. thanks
Use Google for all searches, works much better.
You'll flip your lid when you see it. Badum. OK bad joke... but you essentially use zip ties to hold a now open element filter with a removed lid.
There are about 11 pages of cold air intake threads
Here is one specific to your question.
https://www.corvetteforum.com/articles/c5-intake/
There are a couple similar mods, but a little different. They are the Zip-Tie mod and Flip-Tie mod.
The Zip tie method simply removes the cover and zip ties the air filter in place. The link MAC5 gave is a pretty good write up.
The Flip tie method turns it over and cuts a hole in the shroud to get a cold air (possibly forced air) to the filter.
Take a look at the following links for the flip tie.
https://www.corvetteforum.com/forums...-write-up.html
https://www.corvetteforum.com/forums...a-success.html
The first link also has an attached pdf file that can be downloaded.
Good luck.
Good luck.
search this forum - zip tie mod
