Pulling the C7's Parking Brake Switch While Driving
CorvetteForum Editor
Would it lock up your rear axles? Would it do nothing at all? Admit it, you've always wondered what would happen if you pulled the parking brake switch while driving.
Read the rest on the Corvette Forum homepage. >>
Maxie2U (01-16-2017)
What about in the snow? Maybe someone should try it. Reminds me of high school in empty parking lots.
Last edited by Steve Garrett; 01-16-2017 at 02:22 PM. Reason: No need to re-quote the OP, especially if you're the next person posting.
Moderator
Really not necessary to perform a test. Just read the Owners Manual:
If the EPB is applied while the
vehicle is moving, the vehicle will
decelerate as long as the switch is
held up. If the switch is held up until
the vehicle comes to a stop, the
EPB will remain applied.
Do we know for sure that the Emergency Brake is applied to stop the vehicle when it is in motion and the switch is activated? With all the electronic gizmo's, I wouldn't be surprised if there was some sort of override that utilizes the actual brakes when good ole Dale decides to flick the switch.
Just a thought. Anyone got any solid info on that?
If it could only be applied when the car is motionless, then I would think it would be called PB(parking brake).
Received 1,694 Likes
St. Jude Donor '15
I think the acronym is electronic parking brake, not emergency. I've never thought about pulling it while I'm driving though.
joeybsyc (01-16-2017)
Received 3,289 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
It's a parking brake, not an emergency brake. Zymurgy posted the wording out of the Owner's Manual about it. I've pulled it once while on the interstate; it's like putting the brakes on but doesn't lock them up and when you let go of it they release. No big deal really.
Not sure why on earth it warrants an "Editor" article.
If it's not an emergency, you use the pedal on the floor to slow down the car, not the button on the console.
Received 3,818 Likes
It's really quite amusing that the "Editor" thinks the C7 has more than one rear axle.
The emergency brake works great. The brakes are applied to the point of skidding. It is not violent, I recommend everyone to try it in the event you have an emergency you'll know what to expect. The emergency brake uses the brake drum on the rear wheels and is separate of the normal brake system.
The C7 must be really special then. Every Corvette I've owned has had two rear axles. One on each side of the differential. Now my 56 has a single axle housing, but I guarantee you that it has two axles inside( and I can remove them individually).
about the 3rd day of owning my c7 convertible i pulled it at about 15 mph coming into work as an accident. (my mbz had the top actuator in that area) - anyhow, wheels locked up just the same as 'pulling an ebrake' in an old school brake handle car....
based on my experience with GM's parking brakes in C5 and C6 I would guess that you probably wouldn't notice
Don't know if the C7 parking brake has the squeaky reminder when the shoe material wears down; some other car types don't. Routine inspection would be in order - meaning taking off the rotor/drum and checking that brake shoe.
If the shoe wears into the drum, it is a tough job removing the rear rotor/drum as I assume these parking brakes are automatically adjusting, so they'll continue to adjust and grind further into the drum.
I've been thru this job (the ex drove around forgetting to release the parking brake that was partially applied). I would never apply the parking brake while the car is moving, nor will a high-school kid ever get behind the wheel of my C4 or C7.
