motor mounts
Old 01-17-2017, 02:26 PM
Raith
Raith's Avatar
Default motor mounts
are there any benefits or drawbacks to running solid motor mounts on the c5?
Old 01-18-2017, 01:03 AM
striper
striper's Avatar
I'm assuming this is not a race car. First thing that comes to mind is excessive vibration and noise, the reason mounts typically have some type of absorbent material like rubber or polyurethane in them. I wouldn't suggest going to solids.
Old 01-18-2017, 09:16 AM
Raith
Raith's Avatar
racecar in the making. but for now its my daily driver
Old 01-18-2017, 11:47 AM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
IMHO, I would stick with some sort of compliance. Run a good set of poly mounts. SOLID mounts transmit a LOT of drivetrain NVH.
Old 01-18-2017, 08:40 PM
Last C5
Last C5's Avatar
That's what I'm running on my track car and they're working out great. Make sure you change out front and back together.
Old 01-18-2017, 09:34 PM
kirk tarrant
kirk tarrant's Avatar
white line make set for the 2004 gto same mount with out the corvette tax,
https://www.summitracing.com/int/par...view/model/gto
The following 2 users liked this post by kirk tarrant:
mre1974 (01-19-2017), skydiven4fun (01-19-2017)
Old 01-18-2017, 09:54 PM
v8srfun
v8srfun's Avatar
If you go with solid mounts you will regret it even in a race car they are not necessary
Old 01-19-2017, 07:11 AM
mre1974
mre1974's Avatar
Not sure what the pricing on the Corvette specified ones cost but that there seems like a very reasonable price. Thanks for the info.
Old 01-19-2017, 09:48 AM
Rob Petyo
Rob Petyo's Avatar
Not so!
I run solid motor mounts in both of my C-5's and the vibration is not bad like others say, on occasion it might vibrate but I also run a big cam.
Needed to replace the mounts because on launch we were getting a "bang or pop" from to flexing of the stock mounts that would travel to the back wheels on a hard launch. After replacing, both cars have not have the problem again. My cars are also cutting 1.34 - 1.36 60 foot times.
Old 01-20-2017, 01:59 PM
Raith
Raith's Avatar
Originally Posted by Hot_Wheels
Not so!
what transmission and rear gears are you running to cut a 1.3x 60ft?? thats incredible
Old 01-20-2017, 08:01 PM
Rob Petyo
Rob Petyo's Avatar
A4 with 373's
3,600-3,800 converter
(there is a vid in mu sig)
Old 01-21-2017, 10:54 PM
Raith
Raith's Avatar
A4 with 373's
that's crazy.
I'm also running a sizeable cam in my car. Thunder racing T-Rex grind.. 242/248 duration, .610 lift, 110 lsa... love it.
Old 01-22-2017, 08:53 AM
Rob Petyo
Rob Petyo's Avatar
that's crazy.
I think going with the solid mounts will be good for you then, they are not as bad as you might think at an idle but the tune means a lot.
Best of luck!!
If you run the car in a 1/4 mile and want to post your time slip to see how you compare with others, click here for the C5 Quick List and I would be happy to update the list.
To motor mounts
Quick Reply: motor mounts
