C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Pics of Aftermarket Valve Covers
Old 01-17-2017, 10:19 PM
JohnRR
JohnRR's Avatar
Default Pics of Aftermarket Valve Covers
I would like to get some slightly taller valve covers to clear my roller rockers. If you have some aftermarket valve covers, can you post a picture and a brand part number.
I like the black Holley valve covers with the coils directly mounted on an angle. I would just like to see what others have done.
Thanks,
John
Old 01-18-2017, 05:56 AM
ZRCLONE
ZRCLONE's Avatar
I went with Proform, they come in a variety of colors. Mine were bare so I could powdercoat CRM, made my own brackets.
Old 01-18-2017, 06:55 AM
Undy
Undy's Avatar
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,095 Likes on 578 Posts
Same Proforms, only polished with Proform's coil brackets.
Old 01-18-2017, 07:21 AM
double06
double06's Avatar
What roller rockers did you get?
Old 01-18-2017, 07:23 AM
Undy
Undy's Avatar
OEM... Nothing out there that's more reliable. My originals lasted 88K miles and still were working fine.
Old 01-18-2017, 09:30 AM
Michael_D
Michael_D's Avatar
Proforms.... I'm probably going to try the tall Holleys next. I do not like the coils being where they are.
Old 01-18-2017, 10:03 AM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Holley. Will need to move alternator if you want tall ones using built in mounts.
Old 01-18-2017, 10:30 AM
JohnRR
JohnRR's Avatar
Thanks for the picture; it raises a few questions:
Did you make that special alternator bracket, or buy it?
Do you have to use a longer serpentine belt?
Is that a stock alternator?
If I go with the Tall Holley covers, would I need custom wires?
What's up with coil #7?
What does the red solenoid mounted next to the master cylinder do?
John
Old 01-18-2017, 10:37 AM
JohnRR
JohnRR's Avatar
I went with Yella Terra Ultralite LS7 1.8. They come with an extra thick gasket to get rocker cover clearance. I bought them through Tony Mamo.
www.mamomotorsports.com
John
Old 01-18-2017, 11:32 AM
Unreal
Unreal's Avatar
John
D3 alternator bracket relo
I have a direct drive system, so already have 4 belts. The PS/Alt belt actually could be shorter. It moves it over and down. Same belt went on but less tension.
No it is a billet tech alternator.
What about coil #7? They are aftermarket coils that I had to make custom mounts for. Thats where it fit. Having it up in line put it right in the flex fuel sensor. Stock coils bolt to valve cover with a relo bracket for the coil by the alternator. The "short" holley covers touch the alternator so tall would be worse.
Red thing is fuel pressure regulator.
Old 01-18-2017, 11:58 AM
vertC6
Support Corvetteforum!
vertC6's Avatar
Katech
Old 01-18-2017, 12:14 PM
ratomicZ06
ratomicZ06's Avatar
What do you not like about the coils locations?
Old 01-18-2017, 12:27 PM
Unreal
Unreal's Avatar
I picked up a set of the proform relocates. Was not impressed with the quality of them.
Old 01-18-2017, 03:59 PM
11GrandSport
11GrandSport's Avatar
GM Performance Polished
Old 01-18-2017, 05:10 PM
Michael_D
Michael_D's Avatar
I do not like the coils up and over the top of the covers. Kind of a PITA to remove the covers, wires need to be longer, so buying options are limited (or home built), makes wire and hose routing at the intake a bit more challenging to look descent. And, I just think they look stupid. The coil on cover looks cleaner to me.
Old 01-18-2017, 05:16 PM
Unreal
Unreal's Avatar
Michael, the D3 bracket thing did give a ton of clearance to alternator to valve covers. Sucks it cost $100, but it did what it was suppose to do. Could probably mount stock coil right on there.
I need to find a source for wires too. I just took the OEM ones and had to swap the ends to the other style. Length is fine and didn't change but the coil end did.
Old 01-18-2017, 05:36 PM
MTBSully
MTBSully's Avatar
Where are your coils? Is it a kit? love the hidden coil look.
To Pics of Aftermarket Valve Covers
Old 01-18-2017, 05:39 PM
Unreal
Unreal's Avatar
Most relo kits put them in the fenders, then run long wires from the fender to the wires. Not a fan of that from a performance stand point but it does look good.
Medicdiver (01-18-2017)
Old 01-18-2017, 06:24 PM
11GrandSport
Yeah the coils are mounted on special brackets in the fenders. Have to extend wiring harness and make custom length spark plug wires. I go to cruise ins and car gatherings and wanted it to look a little more old school with the polished valve covers.
Old 01-18-2017, 07:26 PM
Michael_D
Michael_D's Avatar
Thanks Nick. Appreciate the comments, as well as the ID info in the other thread. I'll suck it up and order the Holley covers and D3 bracket.
Quick Reply: [Z06] Pics of Aftermarket Valve Covers
