[C2] SW with a 350
SW with a 350
What do you think the price discount would be for a good condition 1963 split window that had the original 327 replaced with a 350? Any concerns about doing such a replacement?
15k to 20k if not fuel injection car I would think. 10k on the low-side.
If the car is nice?
If the car is nice?
GTOguy (01-18-2017)
The only reason the info is useful is if you are confirming other aspects of originality....e.g. SHP motors shouldn't have a steering damper, etc.
Unless you are going to produce a 'tribute' car, which will prob get you upside down money-wise fast enough to make your head swim
Depending on your intentions, a good running 350 is just fine with minimal discount expected on a really nice car with many original parts and no butchered up body..
Received 3,443 Likes
X3 what these gents are saying. Morley nailed it. Big difference in value between a fuelie numbers correct SWC and the same car in the same condition with a Targetmaster in it. BIG difference. If it was 1975, not a real issue. But in 2017, a big deal.
Prob less of a whack on price than if it was a fuelie...
E.g.
If its now a $75K car it doesn't matter if it would have been a $100K car with a 250hp mill or a $145K car with a fuelie engine...either way its now a $75K car regardless of fender badging IMO..
E.g.
2018 C2 of Year Finalist
St. Jude Donor '12-'13-'14-'15, '19
If you have these questions as a buyer, you're going to be facing the same ones when you're a seller so make allowances accordingly.
On the plus side, with the original engine gone, you're more or less free to modify at will, i.e. restomod.
Yep.
Regardless, sounds like you may be a bit of a novice in the 63 world (most of us are); when you say the car is original other than the engine you're making a lot of assumptions....you should have it looked over before you plunk down your $70K.
