Clutch fork pivot stud
5th Gear
ref: 1996 corvette lt4 6sp
Does anyone out there know the metric thread size of the internal thread in the bell housing for this stud?.
drduppa (01-19-2017)
My first thought is M24X2.0 and to confirm this if you have one of the OE wheel nuts the external thread of those is I'm quite sure M24X2. This is somewhat of a WAG but I'd think so. If you have the stud removed try one of the plastic caps.
Call Jim @ PTS for confirmation. If you need a stud or the retainer I believe he can help you.
http://www.powertorquesystems.com/Contact.htm
Post back what you learn!!!
5th Gear
Thanks for your input
I was quite confident of the M24X2.0 spec but I thought it wise to tag it with the "WAG" and mention confirming with PTS - I understand that BB is from time to time difficult to connect with.
***I had the same issue with this thread as I have from time to time with "dt86" and "Handsome Mike" when they're the most recent responder. I can't see the response until I actually click the "reply" button.
