[C2] Scatter Shield Help
Scatter Shield Help
All ,
I have installed a Lakewood Scatter Shield bell housing with a block plate onto a 383 SBC. The block plate keeps the starter to far away to engage the flywheel. I am going to notch out the block plate to get the starter to sit flush with the block, right now it sits the width of the block plate away which is about 3/16 inch. The unfortunate part is everything is already installed. Has anyone run into this and any help or easier solutions would be helpful. I have already tried a power master starter and returned that for a Mini High Torque starter.
Thanks in advance for any help
Received 1,535 Likes
All ,
Does your starter bolt to the block or to the scatter shield??
Are you running a stock flywheel or aftermarket. I assume the flywheel is properly mounted on the back of the crank with no spacers??
You will need to clearance the hole for the starter in the block plate. I had to do this many years ago to use the plate with a 153 tooth flywheel and its starter.
Received 6,530 Likes
C2 of Year Finalist (track prepared) 2019
Both of our track cars have Lakewood scattershields, and 153 tooth flywheels. One car runs a stock Delco starter and one runs a PowerMaster mini starter. Everything fits and works like it should.
Before you (the OP) start cutting on the block plate, in my opinion, you ought to find out what the real problem is.
Jim
OK, are you using the straight or staggered bolt pattern starter nose?
I am guessing the OP has a 153 tooth flywheel with starters for the 168 tooth flywheel. Sorry it took 12 hours for it to sink in.
Wrong Block Plate?...
The block plate is flush with the back of the block. The flywheel bolts on the crankshaft. I see no way the block plate is the problem. The starter engages the flywheel ring gear. I don't think you can install the ring gear improperly, but maybe.
I am guessing you did the notch out on the block plate and the head was clear to slip in ? Did you have to grind the nose at all ? I am also running headers that will not work with a stock starter.
Block sits away from the bell housing about 3/16 of and inch from the block. When I screw into the staggered bolt pattern holes you can actually see that much of a gap between the starter and the plate.Am i missing something or the starter should sit flush ?
I don't see how this problem can happen.
Jim
Jim
Dont mean to sound like a stupid question just trying to be 110 % sure both applications have the block plate in between the scatter shield and block ?
Location: "You may all go to Hell- and I will go to Texas- Davy Crockett
St. Jude Donor '12
I can remember the block plate on one of my Lakewood equipped cars had another slightly overlapping lightly cutout piece of plate at the starter hole that i guess they made so you could remove it easily if using a different starter and flywheel combination i guess. I also used an L88 HD starter on another project with a 621 bellhousing and 168 tooth flywheel, and I remember having to grind some clearance inside the starter hole of the bellhousing for the big nose on the starter before it would .clear
Are the starters staggered bolt patterns ? Dont know if it makes any difference the holes in the block are the holes in the block they are not moving. There was a power master in there with an alum bell housing and had no issues. What type of exhaust are you running with the Delco to get it to fit ? I have Dougs Headers and having clearance issues with the stock ones. I am going to call Lakewood tomorrow and see what they suggest. I agree with you I find it hard to believe that this set up would be this difficult to line up a starter. I hopefully can come back with a better answer , If not I will attach some pics to get a better idea
Thanks for responding
Thanks for the input
On a side note like the pic of your car. I hope to be joining you soon in repaving the highways with rubber made by MT
larrywalk (01-25-2017)
Just got this of Jegs/Lakwoods website..
http://www.jegs.com/p/Lakewood/Lakew...46185/10002/-1
NOTES
1. Not compatible with 1965-Earlier Bendix-type starters
2. Due to very close tolerances, bellhousings must be dialed-in to ensure proper flywheel clearance.
3. On 1981-Later Mustang, we suggest upgrading the linkage to Hays #490-76-228 (heavy-duty clutch cable & billet aluminum clutch quadrant).
:::EDIT:::
Even though it shows mustang, thats the way the search showed
NOTES
:::EDIT:::
