WANTED. 1963 or 64 hood
WANTED. 1963 hood
Wanted 63 Hood - or a lead to where I can buy a used original one
Prefer a 63 hood but I believe a 64 would also work.
I'm on Long Island in NY
Thank you,
Chris
516-993-2893
Thank you,
Chris
516-993-2893
Hood
Hi Chris -
I don't exactly know your goal, but just as an FYI, 63 and 64 hoods are different. They both have the styling indentions on each side, but 63's have an additional recessed rectangle that permit the cookie sheets to lay flush with the hood. 1964 hoods do not have these additional recesses and cookie sheets will not fit correctly. Additionally, if you have a 63 and the production number of your car indicates that you car should have hood alignment blocks, the 64 hood will not have the bolt backing plates installed to allow mounting the blocks. Hope I'm not running my head and telling you things you already know!
Good luck!
Mike
Good luck!
Mike
Thank you for the clarification. I remember the top recess now that you mention it. I did not think of the bolts. You're great !
ill change to needing a 63 hood
chris
chris
Best 'O Luck...
