C7 HPDE lessons learned
I recently purchased a new C7 Z06 after tracking my C6 Z06 for the past 7 years. I have run numerous searches but have not found a nice all in one thread of others lessons learned tracking the C7 Z06 at HPDEs.
Could you please share your tips for someone looking to run a C7 Z06 at tracks like Road Atlanta, AMP, and Barber?
I have already prepped myself to change the fluids and change alignment per owners manual for track days. I also will be installing seats and 6 point harnesses.
Thanks
Chris
Thanks
Chris
Rx7Rob (01-23-2017)
I've had mine at 3 events now. There isn't much that's unique to the car. Follow the GM guidelines for track prep. This is definitely posted on the site here as well.
As for nuances, there aren't many I can think of. You'll be one of the fastest cars on track and being a Z06 you inherently get a bullseye placed on you by other drivers. I don't think I've given any point bys in the past three events unless I was off pace for some specific reason (i.e. warming up when entering track after a session already started).
Tire pressures like to be around 30-32. Grip will fall off as they rise above 35psi.
Watch your fuel level. A 25 min session at a fast pace will burn a half tank.
Great Tips on the air pressure and fuel consumption.
Thanks
I used Carbotechs on another car and always had issues with vibrations after swapping back to street pads. I had to replace the rotors twice. I've been using Hawk DTC 70s in front and 60s in the rear with good results. This last event I had some modulation issues that I didn't experience before. We're thinking cold brakes or tires since the inexperienced drivers were killing the pace.
Supporting Vendor
St. Jude Donor '11,'13
Thanks
Chris
Thanks
Chris
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Supporting Vendor
How many track days you intend on doing?
Supporting Vendor
Front part # CT1405 Rear CT1718
The latest iteration of the highly successful XP™ series of compounds. XP20™ is a step up from the highly successful XP16™ compound. With an extremely aggressive initial bite, linear torque curve and excellent fade resistance the XP20™ is another major step in progression of the highly successful XP™ series line of compounds from Carbotech™. XP20™ has a temperature range of 275°F to 2000°F+ (135°C to 1093°C+). Carbotech™ XP20™ maintains our tradition of having the outstanding release and modulation that has made all other Carbotech™ compounds so successful. Carbotech™ XP20™ is NOT recommended for use as a daily driven street pad due to possible elevated levels of dust and noise.
A high torque brake compound with a wide operating temperature range of 200°F-1250°F+ (93°C to 676°C+). Carbotech™ XP8™ is the first of our racing compounds. Good initial bite at race temperatures, high coefficient of friction, excellent modulation and release characteristics. Extremely high fade resistance and very rotor friendly. Perfect for track day use with any tire and can still be driven safely to and from the track. Carbotech™ does NOT recommended XP8™ as a daily driven street pad due to elevated levels of dust and noise. Carbotech™ XP8™ is a great compound on the front & rear of most open wheel and sports racers.
This thread has some info on what has worked for me. I absolutely love this car but the consumable costs are very high.
https://www.corvetteforum.com/forums...e-numbers.html
Not that I've ever heard of.
Btw, with the MPSC2's, start around 25/26 cold. Personally I like the tyre a great deal for HPDE's, as I also drive to the tracks instead of trailer the car.
Make sure you go to a shop that can set the rear caster. This is critical to handling.
Also, check the threads regarding the DSC stock controller. Everyone so far is amazed at the profound changes. I'm getting one myself soon.
Since you have the Z07 with the CCMs, please read the threads regarding non-OEM brake pads and rotor 'life'. I have always used the OEM pads with mine, and I'm very happy with the results, although granted the tracks I've been to with the car aren't extremely hard on the brakes.
Bish
Bish
Received 8,928 Likes
The rear rotors don't get as much abuse as the fronts but I used stock pads on them for all 17 track days that I ran last year. I went through one set of pads after 13 days and have 4 track days on the second set. The rotors still look good, no sign of pock marks beginning, still have the shine on them like they did when I first took the car to the track. They look like they could easily go for another 17 days.
No matter my experience you still may be better off looking at replacing the stock rotors. In my opinion they work great but the $1300 each Amazon price for the fronts is a killer if all you will get is 13 track days.
Bill
Supporting Vendor
Thanks
Chris
Thanks
Chris
