Fangs
Received 3,812 Likes
St. Jude Donor '03-'04
I have had the Fangs in black on my 04 since they became available in black (originally they were only available in white and hence the name). Still look good after many years and they do work to prevent scraping up the metal underneath them. Well worth what I paid for them IMHO.
One word of caution when installing them.
You might find that the surface your are installing these fangs to protect, is a bit damaged from scraping over speed bumps, badly angled driveways, parking sops etc.
The fangs will be a bitch to install if the area has damaged, and you will have to use a grinder to smooth out the damaged areas before the fangs will fit correctly.
If there is no damage, installation is quite simple, and does not take very long.
Bob.
Bob.
Easy install if minimal scrapes.
Worked out great for me, white car and white fangs.
Have them also. After buying the car found the radiator support (cage) was damaged. Replaced with a new one and installed the fangs. Did it all on a set of ramps. Great product. Still watch out for big bumps tho.
I just installed some on my 04 easy to install . I had to bend them a little I guess my bars were bent a little easy to do and I already have skid marks on them .. You have to do a little baming here and there to get them to fit right but well worth the effort ..
Received 19,234 Likes
'20-'21-'22-'23-'24
I also have the Fangs installed on my car. As others have said, easy install and they work very well.
Received 3,037 Likes
I bought and installed them for peace of mind when the black color Fangs were first released. Still not a mark on them.
Supporting Vendor
Hi Everyone.
Thank you all for purchasing our Fangs and for all the kind words about them!
If anyone else is interested in the Fangs, more info can be found here.
http://www.saccitycorvette.com/Fangs.html
We have them available for C5, C6 and C7's.
Thank you you,
Christian
Thank you you,
Christian
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
UsernameIsTaken (03-02-2022)
Another vote for the fangs. Easy install and nice looking after install as well as very functional.
Received 1,679 Likes
