VSS Year specific
VSS Year specific
ok guys, bare with me:
I have a 91 s10blazer with 4.3L, TBI, v6 (sawed off sbc) with a 700R4 trans, with an electronic speedo servo.
I'm looking to swap in a corvette 700R4 (cause i burned mine up)
What year did corvette start introducing an electronic speedo servo to their 700R4? I need to know the earliest year i can start looking for a replacement trans.
Thank you everyone in advance
*** I'd maybe delete your WTB because you can't edit the TITLE and you're actually looking for a 4L60e and NOT just a 700R4 like you mention. You might also mention your "LOCATION" if you're serious about the buy. You can put "LOCATION" permanently in your profile but it wouldn't hurt to mention it in your WTB also.
You'll pay a premium for the Corvette transmission that it seems you really don't need. '94 was the first year for the 4L60e in the Corvette.
I don't know why the OP doesn't just source a correct transmission.
**You can cut a "short shaft" 700R4/4L60 to use in the Corvette but you can't "stretch" the Corvette shaft to use in the others.
I should have realized that much earlier but I believe I was still "overcome" by the reference to the "sawed off SBC" LOL. A few months ago I had to source a DRAC for a fellow with an S10 with the 4L60 with the -e VSS.
the reason why is that; I have a tight budget, a 4month old, a wife that stays at home with her. (By my choice) and I work 60 hrs a week. Ergo, I don't have time to pull and build the trans, so I'm looking for a trans that has more robust internals (I.e. one that handles v8 power) from the factory, so I can slap it in and away I go. Being that this is my daily driver, I want the quickest most convenient repair / or replacement. I referenced the "sawed-off sbc" because the first gen 4.3L v6 is essentially a v8 minus 2 cylinders. If I wanted to, I could rebuild that engine using the same internals found in a corvette, (of the same era) as a "super low-buck upgrade" which is essentially what I'm looking to do by swapping in a v8 / vette transmission
Through '93 the Corvette 4L60 was mechanical with the 17 tooth red drive gear and various driven choices. I just checked my '92 FSM and on 4L60-1 it's a generic image (sensor & rotor) but when you get to the actual repair section it then discusses drive gear, retainer etc. It does though very early have an image that displays both ITSS (never noticed it being called that before) and mechanical drive.
