C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
15 in drag radial/zo6
Old 02-02-2017, 09:22 AM
Blue by U
Blue by U's Avatar
Default 15 in drag radial/zo6
I'm doing 15in conversion right now. What size and brand is everyone running? My car will see street, dragstrip and maybe a couple half mile events.
Old 02-02-2017, 09:51 AM
The_Nigel
The_Nigel's Avatar
275/60/15 Mickey Thompson ET Pro is a great tire.
Old 02-02-2017, 10:10 AM
C5 Pete
AMP Racing
Support Corvetteforum!
C5 Pete's Avatar
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
This is a great tire for the track. The downside is it won't last long on the street. The regular 275/60/15 ET Street is probably a better option.
Old 02-02-2017, 12:22 PM
Blue by U
Blue by U's Avatar
I was thinking the 325/50 15 et street r. Anybody got experience with it?
Old 02-02-2017, 12:24 PM
95vettski
95vettski's Avatar
Not thrilled with this tire. First week on the street it worked well after that it was hit or miss. At the track it let go at the top of 1st and 2nd.
Old 02-02-2017, 12:56 PM
Turbo2L
Turbo2L's Avatar
The 275 PRO is a 28" tall from what I remember. The 3053S is a 26".
Old 02-02-2017, 01:16 PM
Blue by U
Blue by U's Avatar
i believe pro was designed for a certain drag class to meet class rules...
Old 02-02-2017, 02:07 PM
ibleedgreen
ibleedgreen's Avatar
325/50-15 MT Street R, killer tire!
Old 02-02-2017, 04:20 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
None of them are good for all of that.
ET street R is good for track/events, not so much on street.
275 pro same thing. For a lower power car, works better than the street R.
Nitto 555r isn't a bad choice for all of the above depending on power level.
All drag radials suck after a few heat cycles on the street.
Old 02-02-2017, 07:05 PM
Blue by U
Blue by U's Avatar
i was hoping you would comment. What are you using? Car should be over 1000 rwhp....
Old 02-02-2017, 07:15 PM
harveyjl
harveyjl's Avatar
325/50 et street R for street, 275/50 et street pro for track
Old 02-02-2017, 07:22 PM
Unreal
Unreal's Avatar
They all work good at track when fresh. They all work for first 10 street trips when fresh.
Depends on what you are looking for a street tire. The ET Rs and other super sticky ones hook decent, but wear extremely fast and lose their grip quickly.
Basically if you want to hook, put a fresh set on for each event. Or swap them at the track, and you may get 3-4 events out of them.
Old 02-04-2017, 10:43 AM
95vettski
95vettski's Avatar
Old 02-04-2017, 02:07 PM
inspector12
inspector12's Avatar
I've run and currently do run the 325/50/15's Mickey Thompson's several sets and yeah work better when new, but never the solution to traction issues although it helped a ton. The Nitto 555's sucked as far as traction, but did last better than most, the NTO5's worked well for the first 2-3 street outings then spun almost as bad as the Nitto Invo's lol! The M/H racemasters were great at track even with a quite a few miles on them and more predictable on the street as they were very consistent, but not as good as a new set of Mickey's but they did do well and held up longer for the abuse I flogged them with. So no real recommendations as Unreal said a new set for an event is what I've been doing, and like he said I haven't had one work like they do new for any length of time. The M/H's were probably the best as far as length of time and performance, but did't really care for the size choices they've had for my current wheels etc... GL!
Old 02-19-2017, 10:03 PM
Blue by U
Blue by U's Avatar
what about mt street s/s 295/55 15 for street use?
Old 02-20-2017, 08:08 AM
Unreal
Unreal's Avatar
As said above, probably fine for 8-10 drives, or 800-1000 miles, then back to ice skating.
Old 02-25-2017, 03:07 PM
Nino S
Nino S's Avatar
ET street R
325/50/15
Great on the track, not so great on the street without a good burnout and dropping them. I actually prefer my 345/35/18 DR's for highway use since I have a lot more stability at high speed and can actually change lanes over 100 mph
To 15 in drag radial/zo6
Old 02-25-2017, 09:35 PM
Blue by U
Blue by U's Avatar
How is everyone running TPS with beadlocks? We just did mine up, but had to use valve stem that came with wheels. Beadlock was blocking regular tps valve stem for airing up.
Old 02-26-2017, 09:14 AM
Unreal
Unreal's Avatar
I don't run beadlock and I don't run TPS with the 15s. When I switch over to 15s full time will put the TPS in the rear.
I'm sort of anti-bead lock. 99% of vette people do it for looks, not because they need it. Yes it looks cool, but it doubles the cost of the rims, makes them heavier, and isn't needed in most cases.
Jason913 (02-26-2017)
Old 02-26-2017, 01:27 PM
Blue by U
Blue by U's Avatar
true, it does make more expensive but it is cheaper to do it first time as to send back to have it done. I have seen cars with way less power than yours move rim inside of tire. We put tps in my first one and had to redo it with supplied valve stem because the beadlock blocked valve stem on the tps. I don't know if people are modifying ring or of there is a different style stem that will make tps work.
Quick Reply: 15 in drag radial/zo6
