[Z06] 630+ rwhp C6Z - B3/AI/MSD/Vengeance Tune
Finally got results - I was shooting for 630rwhp -
First I'd like to say thanks the Good Lord above then thanks to Mike @ VR for tuning it, Phil at AI for heads 2nd to none and Bill @ RPM for perfect N/A research - I did all the work including porting the MSD (ran out of funds for Tony to do it) -
Thank you Jason @ Gearhead Flicks for quick vid since I couldn't be there -
07 C6Z 43k mile shortblock
VR CAI
Ported MSD (me - took two weeks in every detail)
B3 cam
AI 280 heads BTR springs
New LS7 lifters
BTR 3/8 pushrods
LS7 chain
GM gaskets
Stainless Works 2" headers no cats
Magnaflow ZR1 axle back
ATI 10% UD balancer
NW 102 TB
AC Delco ZR1 plugs
Stock clutch (as you can see) and stock injectors -
93 Octane
636rwhp 507rwtq (clutch slip)
Car is a blast to drive and I will replace the clutch next -this is my DD
Here is the reason for low TQ and the clutch slipping
My graph (large slip) overlaid with normal clutch (straight line)
VR said this is the highest N/A C6 they have seen on good old 93 octane -
VR CAI
B3 cam
New LS7 lifters
BTR 3/8 pushrods
LS7 chain
GM gaskets
ATI 10% UD balancer
NW 102 TB
AC Delco ZR1 plugs
93 Octane
Originally Posted by MTBSully
Awesome numbers. 93 octane? How much are the heads milled?
Originally Posted by metalmind1
What are the specs on the B3 cam? I've been thinking about switching and adding an msd and nw102
Solid numbers !!!!!
The B3 cam consistently comes thru... I have a "24X/25X" cam as well, hoping I can get near these numbers. Another solid build with the right parts. Makes me wonder if I'm selling my combo way short with a 265cc port.
My build will be very similar as well, with the exception of stock heads just milled. I've been kicking this cam around. Anyone know what kind of numbers it would put down on stock milled heads (.030)?
No, Mamo Msd, NW 102, Halltech 103MF, Melrose 1 7/8" Headers to B&B PRT mufflers.
But on stock clutch for now as well.
