C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] H/C/E85 Tune results
Old 02-12-2017, 03:34 PM
jayyyw
jayyyw's Avatar
Default H/C/E85 Tune results
Here are some specs on my build:
LPE heads; ported and milled .050"
BTR valve springs
Ferrea exhaust valves
OEM intake valves
OEM head gasket
Stock exhaust manifolds, cats, x-pipe, stock mufflers
Halltech 103, stock tb/intake
ID1000s
Walbro 450
BTR Stage 3 cam
Car made:
515.5/443 on 93
531.9/468 on e65
Tuned by Dave Steck at Dedicated Motorsports in Austin, Tx. (I'll post the sheet later when I can get to my phone)
Overall, happy with the power output. Pretty close to where I was hoping to be. The power feels like when I first got the car, before I got used to the stock power. 2nd gear pulls pretty hard and much faster than before. Headers and Mamo MSD are definitely next on the list.
The car drives great with very little surging. A little harder to take off from a light, but I'll get used to it. Nothing a little more pedal can't solve.
Old 02-12-2017, 06:33 PM
Turbo2L
Turbo2L's Avatar
Pretty impressive for the stock manifolds and cats. Add another 35rwhp with headers and another 25rwhp with the Mamo MSD and you'll really be moving out.
Old 02-12-2017, 07:02 PM
jayyyw
jayyyw's Avatar
Yeah, I believe that is my choke point at the moment. I was hoping for another 15-20whp on E85, but very content with what it put down. Definitely feels like a different car.
Old 02-12-2017, 07:57 PM
AzDave47
Support Corvetteforum!
AzDave47's Avatar
Received 4,509 Likes on 2,598 Posts
That is quite a good gain on E85, probably due to the .050 milling to bring up the CR.
Old 02-12-2017, 08:29 PM
jayyyw
jayyyw's Avatar
Old 02-12-2017, 08:51 PM
DSteck
DSteck's Avatar
I'm pretty certain your factory manifolds and cats are holding that thing back big time. My C6Z made 572whp cam only on stock heads (but had LG Super Pros). You can see in the graph where the power just kinda stalls out. I could actually watch it choke on airflow in the log too.
On the bright side, your factory pump was holding ok. That's not to say it'll suffice once you up the power.
Old 02-12-2017, 09:18 PM
jayyyw
jayyyw's Avatar
Working on gathering money for headers/x-pipe. I plan to swap the pump out in the next week or two. Thanks again man. Super happy with the car.
Old 02-13-2017, 09:54 AM
JaredW
JaredW's Avatar
Do you have any issues using your cruise control? Or where is your surging at? Curious as I am about to pull the trigger on the BTR Stage 3 as well.
Old 02-13-2017, 10:04 AM
Brandon619
Brandon619's Avatar
Jay, I have a question. Are you using the walbaro pump with these numbers, the reason I ask is it was stated your pump might run out of room? I would think that the 450 would work at that power level?
Old 02-13-2017, 02:40 PM
jayyyw
jayyyw's Avatar
Drivability is is pretty good actually. Slight surging under 13-1400 RPMs. I can cruise 6th @ 60 no issues. 4th @ 30 is slight surging.
Im very happy with my cam choice. I originally bought a BTR 4 and stepped down to the 3 and feel I made the right choice.
Old 02-13-2017, 02:42 PM
jayyyw
jayyyw's Avatar
Sorry, a little confusion there. I have the Walbro 450 but have not installed it yet. The tune was done on the stock pump because I didn't have a chance to install the new one before my appointment. I am going to install the new one either this weekend or next depending on my schedule.
Old 02-13-2017, 06:47 PM
Brandon619
Brandon619's Avatar
Got it.
Old 02-13-2017, 08:28 PM
JaredW
JaredW's Avatar
Glad to hear, Can't wait to get mine in! Do you know what they set your idle at?
Old 02-13-2017, 09:06 PM
Nate B
Nate B's Avatar
Pretty sure I saw you out at the wells branch meet Saturday night. I have the silver Z with the plate NAAZTY. I meant to swing by and introduce myself but had to leave pretty quick
Old 02-14-2017, 08:19 AM
jayyyw
jayyyw's Avatar
It's set around 850rpms
Old 02-14-2017, 08:22 AM
jayyyw
jayyyw's Avatar
You had the polished Welds with black roof? Your car looks/sounds great. Are you running 4.10s?
That was the first time I've made it out to that meet. I work every Sunday, so staying out late on Saturday doesn't really work for me. I'll try to make it out more often.
Old 02-14-2017, 04:44 PM
blkscls1z
blkscls1z's Avatar
Any issues with milling that much? Still using stock LS7 .051 compressed head gaskets?
To H/C/E85 Tune results
Old 02-14-2017, 04:56 PM
jayyyw
jayyyw's Avatar
Nope. Car runs great so far. I've only put ~40 miles on the setup as of now.
Old 03-20-2017, 10:45 AM
jayyyw
jayyyw's Avatar
Just a little update:
I installed a set of Texas Speed longtubes and x-pipe with the stock mufflers.
First off, let me say... I'm kicking myself for not holding out for a set of higher quality headers. The TSP set have been nothing but a pain since the very beginning. I am not happy with them at all. I knew it was a hit or miss, fitment wise.. Mine missed, hard. I'm still tweaking them to stop the vibration against the tunnel and rear over pipes.
After a retune, the car put down right about 550whp and 500wtq. I don't have the exact final numbers. Dave/Matt and I were a little surprised it didn't make more power. Could be due to the headers. But, the car does pull much harder than before.
After looking around a bit, it seems like this particular dyno may read lower than a dyno jet, so could be realistically making a bit more. Numbers are subjective anyway. I do plan to hit the dragstrip soon. Just don't know how well my stock clutch will hold up.
I ordered a set of Dragstar 17x10.5 7" BS wheels for the rear and 315/35/17 MT Street S/S tires.
Future plans are still a Mamo MSD manifold, ported TB or NW102, and a better set of headers.
Old 03-23-2017, 11:26 AM
TXGS507
TXGS507's Avatar
Received 1,679 Likes on 1,135 Posts
Awesome.... What a great car!!
"subscribed"...
Quick Reply: [Z06] H/C/E85 Tune results
