cam labor?
02-16-2017, 08:29 PM
cam labor?
I already have an aftermarket cam installed but I just bought a novi 1500 kit. If I decide to have the shop swap the cam during the install for a blower cam how much additional labor is involved? springs and rods done already. Thanks
02-16-2017, 09:45 PM
Probably about 6-8 hours as they'll want to charge but realistically I think it could be done much faster.
02-17-2017, 12:16 PM
Quote:
Originally Posted by
That_White_C6
You don't rush it when doing heart surgery.
A lot of work involved here, radiator out and HB pulled takes a little more time.
02-17-2017, 01:39 PM
The HB gets pulled during the sc install anyway right?
02-17-2017, 01:50 PM
magic c6
No, just the bolt to drill and insert pin.
OP: If the cam works great NA, it should work (at least) good with boost. Mind sharing cam specs on whats already installed?
St. Jude Donor '14, '16
magic c6
It doesn't have to come out, but you have to get enough access to it to pin it. You don't necessarily have to do all the labor required to get access to the cam, but if you're going that far and want a new cam you're only looking at a couple extra hours work.
02-17-2017, 02:00 PM
I have an ATI balancer going in. specs are
- 230/242 .612 114LSA Custom
put down 498whp. want to put down 650ish. Do I need a cam? Do I need meth?
02-17-2017, 02:03 PM
If you are already there, put on a balancer that won't have the chances of failing like a stocker and make you go in again.
02-19-2017, 09:29 AM
magic c6
you don't need the cam and will be much better with meth at that power level
12-12-2017, 12:11 AM
irok
Pretty much the exact cam i have in my 6.0 G8GT. Good manners but pulls like a demon at around 3000 and great gas milage if you just cruise.
12-13-2017, 12:36 AM
That cam will be just fine with the novi imo.
