18 inch wheels on a Z06?
Not too sure about the width, but some companies make 18' that fit.
https://www.corvetteforum.com/forums/c7-z06-discussion/3911992-new-concave-18-forged-wheels-with-z07-calipers-clearance-signature-wheel-sv103.html
Not all 18' clear the brakes, that I know.
Supporting Vendor
Our Forgeline GA1R we can do 18x10, 10.5 and 11 for the fronts and clear Z07 brakes. Call or text me anytime for details and pricing.
Gerry
CW4L, Owner
440-915-6166
Gerry
CW4L, Owner
440-915-6166
__________________
#1 Forged Wheel Master Distributor for Corvettes Worldwide since 2010
Call/Text 440-915-6166
Forgeline*Anrky*HRE*PUR*Brixton*Vorstein er*Akra*Brembo*IPE and Many More....
REVIEWS: http://forums.corvetteforum.com/whee...r-reviews.html
WEBSITE: www.cw4L.com
EMAIL: sales@cw4L.com
PHONE 440-915-6166 CALL OR TEXT ANYTIME!!!
Follow us on Instagram @custom_wheels_for_less
What about running a square set up with 19's all around.
The reason I'm asking all these silly questions is I'm considering buying a Z06 in the future (replacing my C5 Z) and am trying to figure out running costs. I do a lot of track days. Being able to running 19 inch tires would be a big cost savings; running 18s would be even better.
I suppose running a square set up could mess up the suspension settings and rear end ratio, unless I ran a high aspect ratio.
I have a set of 18" Signature Wheels - 11" front & 13" rear that clear APRacing front brake rotors and calipers. Excellent quality wheels, designed and tested in the US, at a great price. Knurled bead area to help prevent tire slip is a plus.
Deity.Motorsports (02-21-2017)
Received 8,927 Likes
315/30/18 fronts 345/35/18 rear. Maintains stock tire diameters works great. You give up a lot of rear traction if you try to run a square setup.
Bill
Bill
NVR2L8 (09-02-2020)
Cruise-In II Veteran
Cruise-In III Veteran
what type of tires with this? rims?
with the sizes you mentioned above are those hoosier r7's or a7's or something else? What brand of rim and rim sizes? Does it clear CCB's on a Z07? do you need spacers. Any rubbing at full lock (steering) thanks
the way to go...
to the OP, CW4L is THE place to get your track rims, I give both Forgeline and CW4L my highest recommendation, (picked up a set of Forglines from Gerry and couldn't be happier) he will hook you up (no pun intended lol)
