Sponsored by: GEM Motorsports
Concerning finding on AC Delco PF64 Oil Filters
Old 02-19-2017, 06:58 PM
spearfish25
spearfish25's Avatar
Default Concerning finding on AC Delco PF64 Oil Filters
I bought three AC Delco PF64 oil filters to have them ready for oil changes during track prep. Thinking back to the relatively recent thread where people discussed prefilling oil filters or not, I decided to look inside them.
I was shocked to find dribbles of sealant on the bottom of the filter interior. At first I thought it was from a weld, but scraping it with a metal pick revealed it was rubber gasket sealant. All three are going back. No way I'm putting this on my car.
Size:  1.82 MBName:  photo45.jpg
Old 02-20-2017, 01:33 PM
SLWRNU
SLWRNU's Avatar
Why not? Doesn't seem to be a problem to me.
Old 02-20-2017, 09:42 PM
spearfish25
Where does gasket material end up if it enters the oil gallery?
Old 02-21-2017, 08:01 PM
1rawTA
1rawTA's Avatar
I sure as hell wouldn't install that on my car either
Old 02-21-2017, 08:25 PM
23/C8Z
23/C8Z's Avatar
Received 5,760 Likes on 3,176 Posts
pay the extra for the R series. Well worth it
If you're really thorough, change out the factory Non Magnetic Drain Plugs for these.
I my C6 i always caught fuzz in my magnetic plugs (non factory either.)
Old 02-21-2017, 08:33 PM
Leo13
Leo13's Avatar
Whats the R series??
Old 02-21-2017, 08:40 PM
23/C8Z
23/C8Z's Avatar
GM performance parts series. "R" for race? Idk. But I know my best friend owns Tune Time Performance and he got it for me along with the mag plugs. He has seen a thing or two along the way (and owns a C7Z also)
Old 02-21-2017, 09:03 PM
Darkvet
Darkvet's Avatar
https://www.corvetteforum.com/forums...lter-pics.html
Old 02-21-2017, 09:42 PM
andreas g.
andreas g.'s Avatar
The UPF 64R is not for corvettes. Check the part number, it's for a chevy VOLT. The internals are different
Old 02-22-2017, 07:57 AM
cheet_code
Support Corvetteforum!
cheet_code's Avatar
The U stands for Ultra & the R for Race. It is the same for any AC Delco filter. They have a little different filtration and higher burst strength
Old 02-22-2017, 10:20 AM
Kracka
Kracka's Avatar
Received 5,708 Likes on 2,917 Posts
Yup, 2nd generation Volt.
It's a $4 oil filter so don't think you're getting any magical.
Based on the fewer, and smaller, inlet holes entering the filter I would be concerned about a lack of oil supply feeding the engine, especially at higher RPM's. The LT1/4 requires a whole lot more than the Volt's 1.5L does.
Old 02-22-2017, 11:05 AM
Speedforhire
Speedforhire's Avatar
^ This.......
I guess the OP doesn't understand filtration. Where do you think those residual manufacturing particles end up? Filtered!
Old 02-22-2017, 11:16 AM
NSC5
NSC5's Avatar
Received 1,100 Likes on 742 Posts
Probably a bad decision on the part of Delco/GM to use such similar part numbers. That sealant material is probably well adhered to the surface and will still be there when the filter is changed. Those "dribbles" are in the clean oil path and you could see if they come loose easily and remove them before installation.
Before installing a filter I turn it upside down and give it a light shot of shop air (no high pressure aimed right at any part of the filter, just a gentle blast) to get rid of any debris. I am more concerned by what may have fallen in when another customer opens the container and accidentally (or purposefully) drops debris in. I remember from my high school days when you would still see people smoking in stores and the person next to me was looking in a filter box as ashes from his cigarette cascaded into the open filter. It probably wouldn't hurt anything but that memory has stayed with me.
Old 02-22-2017, 11:22 AM
Speedforhire
Now we're starting to see some common sense (NSC5) instead of knee-jerk paranoid delusions that the Clintonite members of the Obamanation have thrust upon society.
A little preventive maintenance goes a long way.
Old 02-22-2017, 11:29 AM
NSC5
NSC5's Avatar
Thanks
Old 02-22-2017, 12:09 PM
spearfish25
The sealant scraped off very easily and became loose debris in the clean path as you noted. This is why I'm concerned and will not use these filters. Spending the time removing debris from my brand new oil filters isn't on my agenda. Instead I'll buy the Mobil One filters which don't have this issue and avoid it completely. Figured I'd share with you guys in case those particles could cause issues and the information could be helpful. If you're not concerned, by all means use the filters. It really doesn't matter to me what you put on your own car.
Old 02-22-2017, 12:35 PM
Benavitz
Benavitz's Avatar
Several studies/tests/observations of filter quality I have seen by professional organizations suggest other filter manufactures may be better like the Mobile 1 M1.
To Concerning finding on AC Delco PF64 Oil Filters
Old 02-22-2017, 02:24 PM
Speedforhire
I normally use what affords me the cheapest route, that meets the oem specs.
Old 01-14-2018, 09:29 AM
G-ForceJunkie
G-ForceJunkie's Avatar
Took a look inside some PF64's I just purchased and found a similar thing. However I tried to scrape it off and it wouldn't budge. I wasn't going to worry about it. If the oil can get it off, then it could just as easily take it off from where it's supposed to be, since that surface also sees the same pressure/temperature.
Old 01-14-2018, 02:15 PM
3 Z06ZR1
3 Z06ZR1's Avatar
I use nothing but WIX filter's!
Quick Reply: Concerning finding on AC Delco PF64 Oil Filters
