C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] C6zo6
Old 02-20-2017, 02:27 PM
Bandairas
Cruising
Bandairas's Avatar
Default C6zo6
I bought 2007 c6 zo6 with is modified by katech street attack engine with this mods on it
-ls7 block-K501 camshaft
-65 fast injector
-Fast102
-N/W 102 throttle
-Mahle forged pistons
-C5-r timing chain
-Wcch ported heads
-Psi valve sprins
-Ati damper
-titanium valves spring retainers
-Bronze valve guide
-Bronze guide
-Ti/Mo intake and exhaust valves
-Piston squirters
Double exedy cluch
Full exhoust sustem
And on mustang dyno it just shows 475 rwhp so is it the right hp it can do or i have to do something with the tunning ..?
Old 02-20-2017, 06:16 PM
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
-65 fast injector
-Fast102
-N/W 102 throttle
-C5-r timing chain
-Wcch ported heads
-Psi valve sprins
-Ati damper
-Bronze valve guide
-Bronze guide
-Piston squirters
Double exedy cluch
Full exhoust sustem
That's a badass build...that must be one very depressed/suicidal dyno. Your actual rwhp should be about 100hp higher than that.
Old 02-20-2017, 08:00 PM
LMB-Z
LMB-Z's Avatar
...at least 550 hp
Old 02-21-2017, 12:05 AM
Bandairas
Cruising
Bandairas's Avatar
Default C6zo6
So what should i do
Old 02-21-2017, 12:21 AM
Dirty Howie
Dirty Howie's Avatar
So what should i do
Contact Katech. They likely have the dunk from when the motor was built.
DH
Old 02-21-2017, 12:26 AM
Bandairas
Cruising
Bandairas's Avatar
Default C6zo6
DH
Yes they have thier dyno and it shows 640hp on cranck
Old 02-21-2017, 12:34 AM
MTPZ06
MTPZ06's Avatar
Which equates to about 560 at the wheels...
Old 02-21-2017, 01:47 AM
Boba Fett
Boba Fett's Avatar
find another dyno
Old 02-21-2017, 06:49 AM
Bandairas
Cruising
Bandairas's Avatar
Default C6zo6
Originally Posted by Boba Fett
find another dyno
Yeah maybe if i try dynojet it'll show more 50-60 hp
Old 02-21-2017, 09:25 AM
AzDave47
AzDave47's Avatar
Received 4,499 Likes on 2,593 Posts
Normal dynojet will show about 560-570 for your build. Dynojets for stock LS7's can vary 420-475 at the wheels with 440 "normal".
Old 02-21-2017, 09:48 AM
Bandairas
Cruising
Bandairas's Avatar
Originally Posted by azdave47
normal dynojet will show about 560-570 for your build. Dynojets for stock ls7's can vary 420-475 at the wheels with 440 "normal".
Old 02-21-2017, 02:38 PM
AzDave47
AzDave47's Avatar
That means right around 600rwhp on a happy dynojet. Since you don't have a "before" it is tough to determine the gain of the mods.
My CPR build with the K501,MSD,NW102 and WCCH heads on 91 was 602 on a dyno that stock was 469. What I know is I gained 133 rwhp peak to peak and 170 rwhp at 7000 rpm.
No reason to be disappointed with your Katech build.
Old 02-21-2017, 02:44 PM
Cordes Performance Racing
Supporting Vendor
Cordes Performance Racing's Avatar
Received 1,227 Likes on 774 Posts
run it at the track, that's what matters. It will be obvious if it traps like like a 475 rwhp or not.
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
To C6zo6
Quick Reply: [Z06] C6zo6
