how long do codes stay stored and intermittent code 24
I had the light come on yesterday on the highway, but the next start up it was out again and hasn't done it since. I didn't check it because I had cleaned out the console so no paper clip.
Most likely its the intermittent code 24 I get because of my vss, it comes and goes with no apparent reason to it.
1984 auto
1984 auto
The code should be there. It will go away after a certain number of restarts if the problem does not return. For some reason, I think it goes away after 40 restarts. I have no idea why but thats the number I remember.
And why this 24 is so completely random with the vss not connected at all.
don hall (02-27-2017)
It is caused by an open or shorted VSS circuit. You might have an intermittent connection (like corroded contact in a connector) or an abraded wire intermittently touching ground.
