81 Headlight upgrade LED
Pretty easy. Use factory wiring but you have to cut the buckets and headlamp housings
You need to cut the bucket on the inner circle and cut out the aluminum with a hole saw. It was easy to do.
LEDS http://www.vleds.com/shop-bulb-numbe.../9006-lmz.html
Headlamps high and low beams (Projectors) https://www.dapperlighting.com/colle...nt=25176242056
These have a halo but I did not hook up the halo feature
If you ever had a issue on a trip, you can plug in a factory seal beam if you wanted
The following 2 users liked this post by spedaleden:
Engage (02-24-2017),
ratflinger (02-24-2017)
They do look nice even if the HALO feature is a complete waste as DRLs when you have pop-up headlights.
Have you enlisted a helper to see them as an oncoming car on a dark highway? My #1 problem with aftermarket HID/LED headlamps is their tendency to blind oncoming drivers and I refuse to use them for that very reason.
SwampeastMike (02-27-2017)
