want to upgrade 87 brakes,need info
I'm going to be drag racing my 87 that I did a 383 stroker in,built 700r4 and a d44hd out of my 86 parts car.I'm hoping to be in the high 11s or low 12s and need to upgrade the brakes as I've smoked brand new stock ones a couple times doing a couple high speed stops.I've heard of guys using c5 brakes and am wondering what I'll need and where to get the parts.Cost is a concern as I am about out of money for this build.Added info,I have 96 GS 17" wheels.Thanks to anyone that can help.
bandit666 (02-23-2017)
I did a C5 front brake upgrade some years ago on my '87 coupe. I wanted better braking for autocross and track days. As I recall, the cost of the upgrade at the time (2007) was around $700. You will need an adapter bracket (there is a specific one for 85-87 cars) a pair of C5 calipers, rotors, pads and a new brake bias spring. Also some DOT4 fluid.
The original master cylinder works fine but the brake bias spring needs to be installed in there. It can be done on the car with no fluid loss You can use 85-87-style C4 stainess flex lines and they will fit the C5 calipers.
I used a stock-style C5 rotor simply because of the price and many people here say that many of the aftermarket drilled and slotted rotors really do not provide that much. But use good quality rotors!! I have very good luck with Raybestos Advanced Technology rotors and also AC Delco Professional Grade ones. Note that is no difference between the base C5 calipers and the Z06 calipers except color.
Pad selection is important for stopping power. You will want a good semi-metallic pad that will work at low to medium temps for drag racing or spirited driving. Hawk HPS pads should work for you . The Hawk HP+ pad will also work, but they need some heat in them to really grab. They squeal when cold and will give off lots of dust. Also look at CarboTech brakes.
The big drawback to a C5 front upgrade is wheels. You will need a 17" diameter wheel to clear the C5 caliper! There are ZR-1 stye 17x9.5 wheels available with the proper 38mm offset for your '87. The 275/40-17 tire is nearly identical in dimension to the OEM 255/50-16 tire.
Vette Brakes has a C5 front conversion kit that will have all the pieces you need. Don't bother with any changes to the rear brakes except for good rotors and the same pad type and compound. You will need the rear bias spring so that the rears won't lock up on you during medium braking.
Supporting Vendor
St. Jude Donor '11,'13
Carbotech™ AX6™
The AX6™ is specifically engineered for Autocross applications. A high torque brake compound delivering reliable and consistent performance over a very wide operating temperature range of 50°F to 1000°F + (10°C to 537°C+). The advanced compound matrix provides an excellent initial bite, high coefficient of friction at lower temperatures along with very progressive brake modulation and release characteristics. Many drivers use the AX6™ for street driving as well, even though Carbotech™ doesn't recommend street driving with AX6™ due to possible elevated levels of dust and noise. AX6™ is NOT recommended as a race compound in most applications.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Received 1,400 Likes
I have the C5 Z06 brakes, one of the best changes I've made to the car. The stock Girling brakes are no comparison really.
As stated, you'll need the larger front wheels to clear calipers. 5-spoke ZR1/GS style wheels will clear and are in your offset. I had these first, but now use C6 wheels with the correct offset.
You will need to buy the bracket for the C5 brakes made for 84-87 cars, then buy the rest of the kit to convert. Bracket cost me about $150. Basically the only thing you will need specifically for your year is the brake lines themselves, everything else is a C5 part. I went with Stainless Steel lines for about $100 I think.
The bias spring is a good idea, not strictly necessary, but good to do. Doug Rippie makes it. Its cheap.
The rest is going to come down to pad choice. I stick with PF brake pads in most cars. I think the whole conversion cost around $650-700.
Thanks for the offer,but there are a couple wrecked c5s out my way here in the upstate n.y. area that I know I can rape and pillage for cheap.As for the brackets I'm going to make them.Got all the measurements.Thanks again.
- 1986 Original Owner -
Hey, no problem. Let us know how you make out.
could you share the measurements? i would fab something like this up as well. cheers.
google this:c4 corvette to c5 brake upgrade bracket measurements then click on the picture of the bracket shaped kind of like a boomerang and scroll down,There is a diagram and lots of info.
As long as you have fresh brake fluid, you should have no problem with the stock brake callipers.
Corvette central have Hawk HP Plus brake pads, they will handle the heat no problem. I track my car regularly and with Hawk HP Plus brake pads i did not run into any brake problems.
Friction is what does the stopping, standard brake pads will smoke and turn into powder as you mentioned.
I upgraded to the J55 88-96 callipers after many years of track use of the standard calipers, they were dirt cheap and wanted to put 13 inch discs on the car for looks mainly.
As mentioned you need to change the master cylinder bias spring if upgrading front callipers, or the rears will lock before front.
Link to Hawk HP plus brake pads below.
http://www.parts123.com/corvettecent...50f&ukey=19672
bandit666 (02-25-2017)
Hi
I also did the C5 front brake conversion, bias spring to boost the rear brakes.
I made my own conversion bracket, early C4s are pretty simple.
I think the bracket cost me about $20 to make, including a drill bit purchase...
I bought some used calipers off of ebay for something like $130 shipped, and then another $20 for the bias spring.
Huge difference!
Huge difference!
bandit666 (02-26-2017)
Sometimes .. very rarely... you can grab a bargain on ebay.
Found this on an old post..
Old thread... I know
chris
