The latches won't fit in correctly now and have a huge gap in-between the back of the t top and the top of the car, is there anyone that had similar problems and know how to fix it?
The help would be much appreciated thanks.
I took on my glass t-tops this past summer replacing the WX stripping and had similar problems. I loosened everything up and gradually worked them into place. Like roll the window down, loosen the tabs that slip into the center piece, loosened and removed the chrome bezel on the surround where the pin juts into the body surround...to the backside of the window if that makes sense.
I'm also doing the seals on the 69, and from my readings you are going to end up readjusting the tops AARG! How can a seemingly simple job be such a pain. T
